Brian Hamilton
I know this prolly should be in the drivetrain section, but what an awesome engine idea for the SL-R!!!
Check it out...
msrp starts at $22,995
FWD nurburgring record, and 13.9 quarter mile.
Engines
Ecotec 2.0L DI Turbo VVT
Application: std on SS
Type: 2.0L DOHC I-4
Displacement (cu in / cc): 122 / 1998
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: DOHC, 4 valves per cylinder; dual continuous variable valve timing
Ignition system: individual coil-on-plug
Fuel delivery: direct-injection with a variable high-pressure rail and electronic throttle control
Compression ratio: 9.2:1
Horsepower (hp / kW @ rpm): 260 / 194 @ 5300*
Torque (lb-ft / Nm @ rpm): 260 / 353 @ 2000*
Recommended fuel: premium recommended but not required
Maximum engine speed (rpm): 6300 rpm
Emissions controls: close-coupled catalytic converters, Quick-Sync 58x ignition system; returnless fuel rail; wide-range O 2 sensor
Estimated fuel economy: TBD
Transmission
GM Powertrain Sweden F35 5-speed manual
Gear ratios:
1):
First: 3.38
Second: 1.76
Third: 1.18
Fourth: 0.89
Fifth: 0.70
Reverse: 3.17
Final drive ratio: 3.82:1
Chassis/Suspension
Front: MacPherson independent strut-type with direct acting, 24mm solid stabilizer bar
Rear: semi-independent torsion beam with montoube gas shocks; 24mm solid stabilizer bar
Steering type: electric, power-assisted variable-speed rack-and-pinion
Steering ratio: 14.8:1 (variable)
Steering wheel turns, lock-to-lock: TBD
Turning circle, curb-to-curb (ft / m): 39.4 / 12
Brakes
Type: power 4-wheel disc with standard anti-lock; 38mm Brembo four-piston fixed calipers in front and 40mm single-piston rear calipers
Rotor diameter x thickness (in / mm): front: 12.4 x 1.02 / 315 x 26 (vented)
Disc diameter x width (in / mm): rear: 11.5 x 0.79 / 292 x 20 (vented)
Wheels/Tires
Wheel size and type: 18 x 7.5-inch split-spoke polished forged aluminum
Tires: P225/40ZR18 high-performance
Dimensions
Exterior
Wheelbase (in / mm): 103.5 / 2628
Overall length (in / mm): 180.5 / 4585
Overall width (in / mm): 67.9 / 1725
Overall height (in / mm): 55.7 / 1415.4
Track (in / mm): front: 58.6 / 1490 rear: 58.1 / 1476
Minimum ground clearance (in / mm): TBD
Curb weight (lb / kg): 2975 / 1349
Weight distribution (% front / rear): 60 / 40
Imagine that with a turbo upgrade in the back of the SL-R... Awesome!!
Check it out...
Engines
Type: 2.0L DOHC I-4
Transmission
Gear ratios:
First: 3.38
Second: 1.76
Third: 1.18
Fourth: 0.89
Fifth: 0.70
Reverse: 3.17
Chassis/Suspension
Brakes
Wheels/Tires
Dimensions
Exterior
