FS - Ali Radiator + Group C Intercooler
Brand new, never used. 1x Aluminium Radiator, 726mm x 320mm x 50mm.
32mm Outlets, it has the brackets for mounting the twin thermo fans.
$250. Bubble wrapped and boxed.
Used - 1x 1990's Group C Aluminium Intercooler - Jaguar LeMans (modified)
410mm x 360mm x 101mm thick. Welded / threaded bosses for mounting
65mm outlets
$200. Bubble wrapped.
Located Gold Coast, Queensland.
Hi Troy,
Interested in the radiator, are you able to give both core and tank dims, and mounting dims, need to see if it will suit the P4.
Regards
What part of Brisneyland are you in Mike? I might be able to swing by with it, for a measure-up. The dims quoted are externals, and it's got plenty of space on the mounting plates for fitting. In the 40's they are installed on an angle.
Hi Troy,
I am living and working in central Qld - Moranbah. But the car is located at my Dad's place in Kenmore just near Indooroopilly if that is suitable to you. Should be able to arrange a test fitting at a time and date that suits you as I am in no rush. Let me know your thoughts.
Regards
