IRIDIUM SPARK PLUGS
My old MSD 6AL manual states, not to use Iridium plugs so it all depends on what ignition system you use.
I run standard copper core NGK plugs on all my vehicles which are pretty forgiving. In a worst case I just burn them clean with a blow torch.
Most of my performance vehicles are ignited by MSD 6 series which supplies enough spark to ignite the fuel at any RPM range if its single dual triple or quad carburetted.
On these iridium & platina plugs the gap is pre set and temptation to adjust could lead to failure...
That is what I learned the hard way one day in my past....
good heat range plain copper plug with build in resistance will do for street use...
Paul
