FS EU **KIT NO LONGER AVAILABLE** - *GT40 MK1 Tornado kit*
Adrian Starling
Hi Everybody, I have detailed all items which I am selling as a single job lot, for a Tornado MK1 kit with all Gulf related items. Please PM me with any questions and I have attached a number of pictures relating to the kit and engine choices. Many Thanks, Adrian
Ps. All items are brand new (purchased from TSC/Lee Dawson and Original items in 2024) and ready for immediate packaging and delivery.
Chassis Frame
Full powder coated space frame chassis - TSC Chassis number - RHD
Wishbones front and rear and suspension links - all powder coated
Rear steel uprights
Aluminium panel set - CNC cut to shape
Aluminium floor pan - CNC cut to shape and mounted and powder coated
Lowered driver and passenger floor pan – 1.5 inch lowered.
Build up trolley for the chassis
Suspension
Complete suspension package - Front and Rear, including the upper and lower front ball joints, aluminium front uprights,
aluminium front hubs, front wheel bearings, rear bearing housings (uprights), rear wheel bearings, rear stub axles, and rear drive
flanges - supplied complete with wheel studs and all nuts, bolts, washers, split pins etc.
Coil-over adjustable shock absorbers with springs (set of 4)
Front and Rear anti-roll bar kits including all drop links, bushes and fixings
Steering
Steering column centre shaft with quick release boss.
Steering rack (RHD)
Steering rack mounting kit
Track rod ends (pair)
Steering coupler
Replica Steering wheel (Black leather) with replica boss and badge. The steering wheel is 13 inches in diameter
Hydraulic System
Brake / clutch pedal assembly. (bias adjustable)
Brake master cylinder and level sensor (bias adjustable)
Clutch master cylinder with clevis
Front 6 pot brake kit including callipers, brackets, discs, pads and fixings - Wilwood
Rear 4 pot brake kit including callipers, brackets, discs, pads and fixings - Wilwood
Remote brake servo
Brake servo fitting kit
Brake / clutch pipe unions and bulkhead fittings
Brake / clutch pipe set with clips
Brake light switch
Clutch slave cylinder
Handbrake/ Accelerator
Handbrake lever
Handbrake cables (pair)
Handbrake compensator with fittings
Handbrake calliper kit
Accelerator pedal
Accelerator cable
Cooling System
Aluminium radiator - high performance
Twin radiator fan kit
Radiator water pipe set including all silicone hoses, brackets, and clips
Heater system including on/off valve and trunking with vents
Heater water hose set and clips
Large capacity alloy header tank and cap
90-degree thermostat housing for Ford 302
Fuel System
Alloy fuel tanks (Internal baffles) (Pair)
Fuel filler necks and pipes (Pair)
Fuel filler caps (Pair) - made to the original shape and size
Competition fuel pump with unions (Pair)
Fuel tank sender units (Pair)
No braided fuel hoses supplied
Engine
There are 2 choices of engines outlined at the end of the product list.
Body and Fittings
Full Lee Dawson Gulf MK1 wide body - Front clip, Spider, Rear clip (76 inch), 2 Doors with inserts, 2 Sill panels and single nostril.
Rear spoiler for MK1 (P1076)
Font and Rear body/ clip mounts with fixings
Door hinges with fixings (pair)
Front windscreen with black border and "E" marked
Front windscreen fitting kit including seals and adhesive - 2 off
Impact resistant side window covers including opening flaps with Perspex fixings
Mark Clapp PETG 3mm Headlight and spotlight covers (pair of each)
Glass rear bulkhead window ("E" marked) with mounting frame
Glass rear window, curved and laminated with black border and "E" mark
Front and rear body section cable restraints x 2 off
Replica dash demister grille as original for dashboard
Replica exterior door handles. (polished alloy) (pair)
Door handle catches, strikers, polished interior release handles, pushrods and return springs complete with fixings (pair)
Door lock barrels (pair)
Front and rear over centre Hartwell style latches for locking down the front and rear clips - set of 4
Front and rear body section locators - set of 8
Side sill rubber strip - 2 off
Front body/clip bonnet stops (pair)
Rear clip upper section bonnet pins (chrome) with brackets (pair)
Windscreen wiper motor, drive cable, spindle, stainless steel wiper arm, and blade
Windscreen washer kit including container, pump, tubing, and jets
Door seals (pair)
Roof section rain channel edge finisher
Door cap strips (prevents door top lift at high speeds, as fitted to the original Gulf race cars) (pair)
Gulf style single aluminium 9-hole rear clip/engine vent and Gulf style rear body vents (pair)
Louvered roof vent Gulf single - rear roof mounted
Electrical System
Full and complete wiring harness including fuse box, relays, battery leads and hazard lights circuit. The harness is made to measure
and supplied fully terminated
Front headlight units - Original Marchal Headlamps - LH/RH - 612 26303
Original Marchal headlight mounting frames - LH/RH - 61381003
Lower Round Driving lights - Original Marchal 5 3/4 inch with housing mounts - 613 23002
Rear brake/ Indicator lights - Original and re chromed Simca 1000 - S.E.V Marchal 13.569/13.485
Gulf original Driver Identification light - Green - original Air Ministry R.A.F Lancaster Bomber down light - 5C/615
Complete set of dash switches (Lucas as original), set of 12, including hazard lights, brake test switches, and dash warning lights
Full set of dash instruments including 220 mph electronic speedo, V8 tacho, oil pressure, water temperature, volts, and fuel gauges
with sensors
Front indicator lights – pair
Rear number plate lights – pair
Rear fog light
Rear reverse light
Race number lights 3 – for Gulf door sides and rear number circles
GRP Battery box moulding with seal and fixings
Horn
Interior
Interior GRP panel set including water pipe cover, gear linkage cover and water pump pulley cover
GRP RHD Dashboard moulding
Driver and Passenger GRP seat frames (no foam or covering) - Lee Dawson
Lucas interior rearview mirror and mounting billet section - as original
Wheels and Tyres
BRM replica wheels complete with wheel spinners, lock plates, and wheel nuts - 17-inch wheel set in Gulf orange – 4 off
Knock on wheel adapter kit including hub adapters, drive pins – 4 off
Set of 4 tyres - Toyo Proxes - Front - 235/45 ZR 17 and Rear - 315/35 ZR 17
Price excluding packaging and delivery £60,000.00 (GBP/Sterling)
Adrian Starling
Continued with the 2 engines detail.
Engine 1
1967 Ford 302cu in/5.0 litre R.S (Real Steel UK) Crate Engine 330bhp - with Authenticity Certificate
The engine comes with harmonic balancer and bolt, oil pump and ARP bolt kit, gaskets set, header gaskets, H.D oil pump drive shaft
and FRAM oil filter. Maximum power is 330bhp and max torque occurs at 4000rpm (347ft lbs). Torque exceeds 300lbs from 3-5500rpm.
Included with this motor will be a set of GT Racing stainless steel "Bundle of snakes" exhaust with a pair of silencers.
* Note - the motor does not include alternator, distributor, manifold and carburettor or any other additional parts
Pictures attached of the motor
Price excluding packaging and delivery £10,000.00 (GBP/Sterling)
Engine 2
1987 Ford 302cu in/5.0 litre fully rebuilt Roller Cam engine
Hastings rings, standard size DNJ bearings, Crankshaft re polished, Holley Street Dominator single plane intake (small runner),
Holley 600 carburettor, ARP stainless intake bolts, ARP heavy duty oil pump shaft, Comp Cams fuel pump eccentric kit,
distributor MSD (Fox Mustang), Ford Racing valve covers (needs breathers), new Aerolite 45 spark plugs, Fox Mustang pulleys,
GNB high volume water pump, new front sump and meling oil pickup, Reconditioned Ford timing cover, Ford Motorcraft FL1A oil
filter, Stainless timing/ water pump sump and rocker cover bolts, Felpro 9333 pt1 head gaskets, new ARP head bolts
(70ft lb in 3 stages, with ARP lube), Heads refurbished with new 220lb SBI valve springs, cleaned and relaped, New Ford roller lifters
with retainers and hold down kit, New Melling pushrods and New Summit Racing spark plug wires. The engine has been accurately
repainted to the original Ford colours of the period. All cylinders have been tested at 120psi, and the rings still need to bed in.
Price excluding packaging and delivery £6,000 (GBP/Sterling)
Adrian Starling
Engine 1
1971 Ford 302cu in/5.0 litre R.S (Real Steel UK) Crate Engine 330bhp - with Authenticity Certificate
Engine 2
I wanted to clarify that engine 1 and 2 do not form part of the kit job lot and can be bought separately, so apologies for any confusion. Thanks, Adrian
Thanks Adrian can I have a chat about it to get more details? I am in redhill is that close to you? My number is 07736 381240. Thanks Paul
Adrian Starling
Chassis Frame
Rear steel uprights
Suspension
Steering
Steering rack (RHD)
Steering coupler
Hydraulic System
Remote brake servo
Brake light switch
Handbrake lever
Accelerator pedal
Accelerator cable
Cooling System
Fuel System
Engine
Body and Fittings
Door seals (pair)
Electrical System
with sensors
Rear fog light
Rear reverse light
Horn
Interior
Wheels and Tyres
Price excluding packaging and delivery £62,500.00 (GBP/Sterling)
*Update*
All elements of the transaxle have been removed from the list and the reduced price is £62,500.00 (GBP/Sterling) excluding packaging and delivery.
