J Jonny P. Nov 1, 2010 #1 Hi Can someone help me with the dimensions on the metalastik couplings. (the bolt circle, bolt thickness and the thickness of the coupling) I dont know what to search for :cry:. Regards. Jonny...
Trevor Booth Lifetime Supporter Nov 1, 2010 #2 Mission Sales and Supply - Metalastik Rotoflex® Coupling try this site or search for rotaflex couplings
J Jonny P. Nov 3, 2010 #3 Tthank you Trevor Do you know the part number of the coupling used for the MK1 with the ZF? regards: Jonny..
Trevor Booth Lifetime Supporter Nov 3, 2010 #4 sorry , cant help with part number. someone may be able to measure up a ZF flange and get the PCD of the 3 bolts for you. This will identify them for you
Pedro Guest Supporter Nov 5, 2010 #5 Try this place, they should be able to help, these are the ones used on the 40's Hewland Gearbox | Jerico Transmissions | Quaife Transmission | Tilton Clutch | Racing Driveline
