So, how about the next step in the Superlight SL-C's development? Let's make it in aerodynamics.
Present State of SL-C Aerodynamics
Right now, we put a large wing on the back of the SL-C.
Photo c and courtesy of RCR/Superlight
That gives us downforce, but it also adds a lot of drag. It also adds weight to the car.
Suggested Improvement
How to add downforce without a commensurate permanent load of drag? I suggest that a good example to follow would be the new Pagani Huayra.
2011 Pagani Huayra c and courtesy of Pagani.com
Pagani's press release Pagani unveils the Huayra - Car Body Design states this about the Huayra's aerodynamics:
Front flaps retracted into nose. Photograph c and courtesy of Pagani.com
Rear flaps retracted into rear bodywork Photograph c and courtesy of Pagani.com
Forward flaps deployed. Photograph c and courtesy of Pagani.com
Rear flaps deployed. Photograph c and courtesy of Pagani.com
We put the flaps on the SL-C, optimize the rest of the car to be a wing, slap on a control system and--voila! a Pagani Huayra at 1/10 the price.
Conclusion
Fran is only
Seriously, what do you think about this new approach to the SL-C's aerodynamics? It could improve the car.
Bassanio et Portia
The Huayra adopts the concept of a wing, whose properties can be modified by varying the front ride height, which can be adjusted dynamically, and by adjusting the 4 control flaps on each of the four corners of the car.
The behavior of the flaps is managed by a dedicated control unit that is fed information from the ABS and ECU, which pass information about the car’s speed, yaw rate, lateral acceleration, steering angle and throttle position.
In addition to this, the air flows – both outside and inside the car – were optimized to guarantee the optimal downforce and stability under all conditions. . . . The rear bumper integrates the diffuser . . .
Conclusion
Fran is only
- running a full-time race team
- making new cars for us insatiable customers
- fielding foolish posts on a number of fora, and
- creating new products
Bassanio et Portia
