Thread: 351W vs 302W
Old 03-26-04, 12:49 AM   #13 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: 351W vs 302W
Thanks guys - a mountain of info & much appreciated !
If I had known that I was going to fit a 351W, it would have been easy. However, based on a 302W, I installed the roll-bar & rear braces accordingly. Measurements & some pics from Bill Bayard indicate that the 351W is going to be really difficult - the rear header pipes would run straight thru the roll-bar braces (& considering the hassles in post-fitting these, mods are pretty-much out of the question).
Bill (DRB#5) - your setup should be fine as you have the roll-bar inside the cabin & the braces therefore everything is moved forward & your braces meet the chassis further forward (& outwards) than mine. (My braces hit the chassis right at the rear-most part, just on front of the suspension towers).
Gary, the thought of a "loaner" engine has crossed my mind, but the RTA's detective skills are a bit of a worry - they are good at this (but nothing else). Yearly inspections which check engine/VIN numbers are the norm, so running a "round-robin" with one legitimate engine could prove to be a really big challenge / risk !
Kevin - thanks for the "heads-up" on balancing - yet another potential sink for money !! With a new engine, it looks like I would have to have the whole show re-balanced.
Chris, the quad-cam is out for now - DRB tells me that chassis mods are required to get a cross-over exhaust system to fit.
Howard, yes California is GREEN, but not half as green as my bureaucratic "mates" at the RTA ! For "green", read "new at the game / uninformed / uninterested" and specially, "envious".
Kind Regards,
Peter D.
delaneyp is offline   Reply With Quote
