Old 03-07-07, 01:25 PM   #43 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: frank's kva
Originally Posted by Frank Beuker
thank's this will of help
i've orderd new upright from john wisher so i can determen where ever i want to put the connectionpoint for the tierod
is there a rule for the position of the rack (to the front or back)
frank
Just seen this one Frank. If you've already got your rack then it will only go one way. If you are using the rack in the photo it will need to mounted ahead of the
wheel centreline. If you mount it behind when you turn left the car will go right. Could take a bit of getting used to!!
Good luck with it all
Russ
Russ Noble is online now   Reply With Quote
