Old 03-25-07, 10:28 AM   #48 (permalink)
wbmusarra's Avatar
wbmusarra
Location: Snellville, Ga. "Everybody's somebody in Snellville"
GT40: DRB#5
Rep Power: 19 wbmusarra is a name known to all
Re: frank's kva
The links helped a lot. I am ready to start assembling the shifter and pieces. Have the plan worked out with rough drawings. Now to see what kind of problems it raises, which I am sure it will. My suspension is the C4 corvette, so I have what I have. I am not well versed in the engineering and geometry of the steering. So I will leave that up to the guys that will be working on my setup. The uprights(front) are being modified so that I can get some decent brakes for it. I will let all be known when I get around to an update. Should be in a week or two. All the parts should be in by then. I will probably have to redo the bump steer thing again as the steering arms are being modified also.
DRB#5
351 Windsor bored, stroked internaly balanced
DIS
TWM 8 Port F. I.
930 Porsche LSD
wbmusarra is offline   Reply With Quote
