| Re: frank's kva i had to change the position of the steering wheel more to the left
two reasons
- the steering wheel was al the way to the right almost next to the seat
- the angle of the shaft was wrong to the steeringrack if i didn't change the position i had to put a extra joint in between
but the result was that i've got to change the dash put the rev and two other meters more to the left so the dash also wasn't right to begin with
how is the position of the steeringwheel by the gtd's/rcr's.....
are you sitting straight forward ,or do you have to sit in a angle to grab the steeringwheel?
some pic's of the dash before and after (still busy so not finished)
and the new brackets for the shaft |
