Thread: Rcr 40-31
Old 09-18-07, 06:11 AM   #87 (permalink)
Rob
VintageVenom's Avatar
VintageVenom
6 Tenths
GT40: RCR-40
Rep Power: 11 VintageVenom has much to be proud ofVintageVenom has much to be proud of
Re: Rcr 40-31
Chris,
One idea/suggestion:
Your roof is likely "drooping". Essenstially, there is no support for the front of the roof at the moment, as the windscreen is not installed, so when you close the doors, the roof likely drops down some from the compression of the seals. Would suggest making a wood prop to hold the roof at the correct position while your assessing this. Then you can determine what the actual misalignment it. I would suggest doing this by setting the windscreen in place and sizing the prop so there is just still a small gap at the top of the screen. I kept my prop in for ALL fitment steps.
My two cents....
Rob
aka "VintageVenom"
www.vintagevenom.com
VintageVenom is offline   Reply With Quote
