Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > CAV GT40 Talk
CAV GT40 Talk CAV GT40 discussion sponsored by VIP Classics.
Old 02-01-08, 08:10 AM   #41 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Rep Power: 5 JCoop will become famous soon enough
Re: drivetrain/clutch shutter! tranny mounts?
Jean, thanks for your excellent attention to owner's woes...
Quick question: do the new motor mounts allow any fore/aft and up/down adjustability?
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
'67 Austin Mini Cooper S
MB E350 4matic (commuter)
Looking for a Cessna Aerobat
JCoop is offline
Old 02-06-08, 09:22 AM   #42 (permalink)
Auto Futura's Avatar
Auto Futura
GT40: CAV Manufacture
Rep Power: 5 Auto Futura is a jewel in the rough
Hi Ray
The answer is yes, and I will post pictures next week. I am racing the whole weekend, and will only get to it on Monday.
Jean
Auto Futura is offline
Old 02-06-08, 09:48 PM   #43 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Fantastic!
Good luck racing and looking forward to those pics!
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 02-07-08, 10:08 PM   #44 (permalink)
MK -IV J6's Avatar
MK -IV J6
GT40: NYC,USA
A few thoughts. Ferrari solved this problem with an internal rubber dampener in the clutch assembly. After the clutch before the gearbox. The engines in my P 3/4 412P and Dino Competizione are not only solid mounted the water and oil flow through the chassis tubes so the mounts are SOLID. This was a very clever solution as it allows a very stout clutch which can be engaged with out setting up sympathetic osculations in the drive train. Early GT 40's used these rubber isolators between the gearbox and the half shafts for the same reasons. These have to be looked at and replaced from time to time but they work very well.
Best
MK -IV J6 is offline
Old 02-08-08, 12:26 AM   #45 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 37 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Porsche used a similar system in their clutches too...for production 911's
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 02-18-08, 05:20 PM   #46 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Here's how my mounts turned out after using Casey's suggested fix. The upper RH is a bit chewed up as the poly is really hard to chop without cutting off one of your fingers. My reinforcements to the platform look rough in the pics but they're OK in person
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 02-20-08, 07:37 PM   #47 (permalink)
chaparralman's Avatar
chaparralman
GT40: CAV MK1
Rep Power: 1 chaparralman is on a distinguished road
Great job Jcoop!
Does that help your car as much as mine?
Casey
chaparralman is offline
Old 02-20-08, 10:31 PM   #48 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Quite frankly, I didn't see that much of a difference from when I reinforced the platform. Welding in square inserts showed a major improvement after the platform had broken from all the torque and shuddering. Granted, I really haven't driven the car any distance; maybe a mile or so to gas up. The weather's just been too dreary for me.
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 03-13-08, 05:24 AM   #49 (permalink)
Auto Futura
Hi Guys
I have tried many times to post these, so here goes..( again)
Old 03-13-08, 05:29 AM   #50 (permalink)
Auto Futura
...and gearbox mounts for Audi 6-speed
Old 03-13-08, 05:31 AM   #51 (permalink)
Auto Futura
...and race-day
Old 03-13-08, 08:10 AM   #52 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Thanks for the pics, Jean.
Those motor and tranny mounts certainly look the bit. Just to make sure before I place my order, do the motor mounts bolt on directly to existing holes in the chassis (pre-100 car)?
Race day pic looks awesome!
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 03-14-08, 06:35 AM   #53 (permalink)
Auto Futura
Hi Ray
Yes they do, but you would need to drill the top two holes into the pre-100 chassis. A threaded plate is supplied, which fits inside the chassis from underneath.
MUCH stronger than 'old' CAV mount.
Jean
Attached another photo of the beast....
Old 03-14-08, 06:43 AM   #54 (permalink)
Auto Futura
...I hate computers
