| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Build Logs For build threads and build diaries only. |
06-11-08, 11:42 AM
#61 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Re: Toms RCR 40 Trackracer John,
i´m happy that you like it.
I think i place the oil cooler beside the transaxle and use the air ducts for suppliing fresh air to the engine compartment
yes i´purchased the original style brake ducts and will mount it
TOM
__________________ RCR 40 ; LEVY RACING 331; G50/05; gulfwide |
06-11-08, 12:46 PM
#62 (permalink)
| | Bill D I Have No Life
Rep Power: 33   | Re: Toms RCR 40 Trackracer Your progress and attention to detail is #1 all the way!!!
__________________ Bill D
RCR GT40 Mk1 Gulf |
06-11-08, 05:51 PM
#63 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Re: Toms RCR 40 Trackracer Thanks Bill
Can´t wait to hear your baby roar :-))
TOM
06-11-08, 08:11 PM
#64 (permalink)
| | VintageVenom 5 Tenths
Join Date: Oct 2005 Location: Michigan, USA GT40: RCR-40
Rep Power: 10   | Re: Toms RCR 40 Trackracer Top notch Tom.... |
06-12-08, 08:12 AM
#65 (permalink)
| | CESLAW Gold Supporter
Rep Power: 5  | Re: Toms RCR 40 Trackracer Tom: Excellend idea on the engine ducting. I was debating on how to fab that duct. You just answered the question. |
06-15-08, 06:28 AM
#66 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Break/Engine Ducting Finished installation of engine and brake ducting.
Bill Houghs brake ducts fit ok in the original style inner panels of RCR with some adaptations. One have to cut back the exit opening of the brake duct to clear the upper radius rod at full suspension travel. The ducts where glued in with the same high shere epoxy glue.
The intake opening of both ducts will be blended in with fiberglass to the opening of the rear clip to achieve a nice and smooth finish.
The rear brake ducts are improving the already high stability of the inner panels and the clip itself even further.
right hand side brake duct
left hand side brake duct
total inner view
right side intake
left side intake
awh:132
TOM
06-15-08, 03:25 PM
#67 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | custom flares Started with my flares.
First i thried the original gulf flare, but with the originals having much bigger diameter tires it just was to big for my 345/35/15 and it looked to bulky in my opinion.
I discussed with Fran if his plus 2" would fit, but he thought it will be to close, because my tire is extending 3" over the stock narrow body. So to achieve the look i want i have to fabricate flares specific to my car.
The look i wanted to have is this one
I had an old set of P.... RSR flare extension ( screw on) laying around. I used this to establish the wheel well line, but as much i tried i could not get the well so close to the wheel as in the above picture, without having interferance with the tire when it travels through its suspension move. The car above is probably very stiff springed to be able to run a design like this. Anyway i decided to let the "lip design" go and do something close to the gulf design, but less bulky with a lot of tire to see from the front and from the rear ( like above) and very tiny sill extensions. This is what i came up with. Using the RSR flares as a basis ( screwed and glued to the cut out body) i´m building the rough design with stringers made of balsawood and PU foam.
With the stringer design the shape is repeatable from right to left side, because i kept the cutoffs ( which will serve as a template for the other side). Intention is also to have a nice blending in with the existing body
Stringers and PU Foam
Rough design
A lot of tire to see , but still covered enough for the officials.
Rough design with wheel fully tucked in at full suspension travel
After finalising the rough shaping, i will cover it wíth a thin layer of glass and then filler it. After sanding smooth, a negative mould will be produced.
Finally the positive parts from this mould will be attached to the body, after all the " mould crap " would be cut of.
awh: 136
TOM
06-15-08, 07:52 PM
#68 (permalink)
Rep Power: 10   | Re: Toms RCR 40 Trackracer Lookin good Tom. Eager to see the next steps. |
06-16-08, 12:38 AM
#69 (permalink)
| | John Rookie
Rep Power: 2  | Re: Toms RCR 40 Trackracer Hi Tom,
Guards are looking good.
The link to your brake ducting photos has been lost, could you see if you could fix up pls or post again. |
06-16-08, 01:33 AM
#70 (permalink)
| | EGLITOM 3 Tenths
06-17-08, 08:15 AM
#71 (permalink)
| | ckouba 5 Tenths
Join Date: Feb 2004 Location: Phoenix, AZ, USA GT40: RCR40-31
Rep Power: 10  | Re: Toms RCR 40 Trackracer Tom-
Looking GREAT! Keep up the good work. |
06-18-08, 07:50 AM
#72 (permalink)
| | John Rookie
Rep Power: 2  | Re: Toms RCR 40 Trackracer Tom, did you make the rear brake ducts or buy them? I've had a bit a look around, but haven't found a source for them. I've noticed a couple of builds have used similar ducting. |
06-18-08, 05:38 PM
#73 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Re: Toms RCR 40 Trackracer John The source for the brake ducts is Bill Hough. He is producing a lot of Original GT40 Glassfiber parts. . His User name is " FRPGUY" may no resin cure before it's time^ I needed to rework the left hand side one to fit, but other than that they are ok ( even if a new mould wouldn´t heart) I contacted him via PM on the forum.
06-20-08, 04:12 PM
#74 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Flares roughly shaped
06-20-08, 04:22 PM
#75 (permalink)
| | fsts2k Rookie
Rep Power: 5  | Re: Toms RCR 40 Trackracer Looks great! The craftsmanship of this build is incredible. |
06-20-08, 06:40 PM
#76 (permalink)
I think you have captured the look very well.
The distance from the top of the wheel opening to the top of the fender looks greater than I would expect, but I suspect it is due to camera location and using a wider angle lens closer to the car. A shot standing further back with a bit of telephoto may cure what I assume is an optical illusion.
Really nice work. Where do you find the time?
Does the duck have a name? |
06-20-08, 07:16 PM
#77 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: Replica
| Re: Toms RCR 40 Trackracer What Chuck said x2...
I love the look and I ALSO want to know where you find the time!!!  |
06-20-08, 11:25 PM
#78 (permalink)
| | Pantera1889 10 tenths
Join Date: Jul 2003 Location: Maryland,USA GT40: RCR MK1
Rep Power: 18   | Re: Toms RCR 40 Trackracer Looks perfect Tom!!! Don;t change a thing! Not an easy thing to do working with such a short tire...
Keep up the great work.Everyting you have done so far is simply astonishing!
Do you have molds to make duplicates of these flares for other RCR customers????
__________________ RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889 |
06-21-08, 02:27 AM
#79 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Re: Toms RCR 40 Trackracer Chuck, Randy, as Ron mentioned in his build log, the day has 24 hours and need for sleep is overestimated ( currently i average 5h). Chuck it is not an optical illusion( you have an sharp eye as well). THe tirediameter is app 1 3/5 " smaller than for example the AVON CR6zz 295/50/15. (see tirelist onby) , so to close the gap towards the tire i had to extend the fender further down, but on the track i plan to use DUNLOP CR 82 or the MICHELIN TB5 and they are in a range of plus minus 1/2" in Diameter of the PIRELLI.
RON: Yes i will do negative moulds of this flares, because i intend to have a clean ligthweight solution, so i will cut away all the foam crap and fit nicely the positives out of the moulds. The moulds will be done in EPOXY resin, so the should be very rigid and less prone to shrink and distortion. The positive parts will be made with high quality woven glass, with a material incorporated to dampen stone chips ( and avoid there imprint on the outside) probably done with vinylester resin ( like the original RCR). They will be white gelcoated. The moulds i will makes by myself, but the positives will be laid up by a pro ( usually does prototypes and development for DAIMLER AEROSPACE and DAIMLER BENZ , guess where the SLR seats come from ?), so they will be very high quality and hopefully fit pretty good.
If any other RCR customer is interessted i would have him making copies for them as well. If more people are interessted i would talk to FRan if he would like to do it and send a set to him to copy.
TOM
Chuck BTW. We don´t give them names, because they will end up in a pan at xmas ;-) | |
