Old 10-03-07, 12:09 AM   #1 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
GT40: Albany west Aus
Rep Power: 7 albanygt40 is a jewel in the rough
IDF Weber set up from racetep.com
Hey
Guys I'm thinking about purchasing a 8 stack IDF set up from these guys
Ford V8 Webers 818 764-1901
Has anyone used these Guys before?
and for all the Weber experts out there please comment on this set up
and any advice greatly appreciated.
FFR Coupe #385 5ltr T5 44IDF's LSD
albanygt40 is offline
Old 10-03-07, 12:41 AM   #2 (permalink)
car guy's Avatar
car guy
GT40: Bailey Edwards
Rep Power: 5 car guy is on a distinguished road
Re: IDA Weber set up from racetep.com
I believe those are IDF's.
car guy is offline
Old 10-03-07, 12:47 AM   #3 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Fixed up error in post.
Old 10-03-07, 06:47 AM   #4 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Re: IDF Weber set up from racetep.com
I got the book Weber Carburetors by Pat Braden which has a good write up on setting up some Quad IDF's on a SBC. I've played with 45 DCOE's before so hoping that quads should be similiar in setting up. Any other reading material recommended and does anyone have a copy of Olivers CD
as I might need it aswell.
Old 10-07-07, 06:10 PM   #5 (permalink)
Rick
Rep Power: 4 Rick is on a distinguished road
There is a set being sold by an individual on the Club Cobra site. Appears to be a good price too.
Rick is offline
Old 10-07-07, 07:31 PM   #6 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
Rep Power: 12 chuck 1 will become famous soon enough
that seems a reasonable price for the IDF's to me, and I hear that IDF's are a littler easier to tune than IDA's. The set up should work well with a mild 302
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 10-08-07, 09:15 PM   #7 (permalink)
mustangII460
Rep Power: 2 mustangII460 is on a distinguished road
Dave,
I have a Factory Five Roadster with 48mm IDF's. If you or anyone else buys these I have a solution for the linkage problems, (Yes there is a problem.) Since there in no boss in the middle of the intake,( Design Flaw IMHO) some minor mods have to be made. There are several ways to do this. Also the accelerator pump shafts hit every valve cover I tried, (Lots.) I modded my covers, another put carb spacers to lift the carbs up.
I not selling any product, but I will show anyone how I overcame the problems I encountered with the IDF's. ( Homemade solution.)
When I purchased these last year I got ZERO help from the vendor on how to set up linkage, tune them or information on them. After having them running on a 331 for the last 6 months, Ive become semi-pro with IDF's.
YES,, I would use them again facing the same problems I had.
Again, anyone with questions or anyone that found this post by searching that needs help. Let me know.
Cheers,
mustangII460 is offline
Old 10-08-07, 10:10 PM   #8 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
Pierce Manifolds sells the center piece for 12 bucks that you bolt to the manifold to hook up a center pull for the linkage. It looks stock when on, and took me all of 5 minutes to measure and put it on. Also Stephen at Pierce knows the linkage parts needed for center pull set up and sells them all. here are some pics of the piece.
chuck smith
CAV MONO GT40-302
chuck 1 is offline
Old 10-08-07, 10:10 PM   #9 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
chuck smith
CAV MONO GT40-302
chuck 1 is offline
Old 10-08-07, 10:48 PM   #10 (permalink)
Sandy's Avatar
Sandy
Gulf GT40
GT40: RCR GT40 Gulf
Originally Posted by albanygt40 View Post
Hey
I purchased a TWM and Halltech EFI from them. They are local and were pretty helpful. Ask for Steve.
Sandy
Sandy is offline
Old 10-09-07, 12:52 AM   #11 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Frank any chance of a pic of your fix??
Thanks Chuck ,may have to look them up, do you have a link??
Cheers Guys.
Old 10-09-07, 04:50 AM   #12 (permalink)
Rick
Hey Chuck...........who sells those gaskets???
Rick is offline
Old 10-09-07, 09:25 PM   #13 (permalink)
mustangII460
Dave, heres the crude working solution. I made a plate thats affixed to the 4 inside carb bolts. I used a stock EFI throttle cable and L shaped cable housing holder to secure the cable to the plate. All of the linkage lines up and pulls straight with no binds. I planned on cleaning things up after my testing of its done. I wanted to see if I stressed anything by doing it this way. So far it looks great. 4k miles.
The other way would be putting the boss in the middle of the intake as shown above. I'll admit it scared me a little bit doing it that way. I would have most likely welded it in the middle if I went that direction.
Either way would be fine for me. Although the boss would probably look better, or correct.
Old 10-09-07, 09:35 PM   #14 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
here is the link
Weber Carburetors,Carburators,Conversion Kits - Pierce Manifolds Inc.
Rick, that is my poor attempt at gasket making, I promptly ordered the proper ones.
chuck smith
CAV MONO GT40-302
chuck 1 is offline
Old 10-09-07, 09:38 PM   #15 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
my 427 has the cross piece bolted to the carb base and it works quite well, notice the way the linkage arms are set up differently than mustang11460 however
chuck smith
CAV MONO GT40-302
chuck 1 is offline
Old 10-09-07, 10:24 PM   #16 (permalink)
mustangII460
I was hoping this winter to clean mine up and have it look a little more like the one Chuck shows above.
Certinally glad to see a few other ideas.
*Note, mine would be pulling from the rear on the GT40. Not sure if that would be the desired location for most of you. I doubt routing it around the distributor would be anymore trouble?
Old 10-09-07, 11:01 PM   #17 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Frank any chance of a pic of the acc pumps hittting the R/covers?
Cheers for the help Guys.
Old 10-09-07, 11:29 PM   #18 (permalink)
CESLAW
4 Tenths
Rep Power: 7 CESLAW is a glorious beacon of light
Here is a pic of the accelerator pumps of the IDFs hitting the Gureney-Weslake valve covers. Have not yet tackled this issue. I suspect may have to grind away a bit of aluminum to give it adequate clearance. If any one comes up with a better solution, let me know.
By the way, the "Ford Racing" covers that came with my engine did not seem to have this clearance problem.
Chuck
ID:	24348   Click image for larger version
CESLAW is offline
Old 10-09-07, 11:30 PM   #19 (permalink)
mustangII460
Dave, Inglesse # NG1013 is a spacer for under the carb, $25ea X 8. .... A member on another website found them. I might have went that way if I had known about them at the time.
( Hold on for this ) I drilled corresponding holes in each valve cover. I pressed in 1/4 copper pipe end caps into the cover, (Think freeze plug.) When the shaft moves toward the cover, it goes into the relief area.
My way works fine and certinally would be an option for those with tight hood clearance. Otherwise the spacers would be the way to go.
Hopefully all of these methods discussed can help people decide what they want to use. Instead of eating up time figuring out how to make things work.
Old 10-09-07, 11:32 PM   #20 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
