I agree with Tim, this is what I have...
RBT continuation of the ZF gearbox with the following ratios, 1st 2.43, 2nd 1.61, 3rd 1.14, 4th 0.826, 5th 0.642 final 3.56. My gearbox has the new and stronger 2 piece input shaft.
Levy Racing stage 5 engine with dart block and heads, forged internals 399 cuin internally balanced, 625 hp at 7500 rev, fully race machined, solid roller cam, shaft rockers, custom cam grind, HP pin oiled lifters, aluminum flywheel and clutch and Borla EFI with 58mm throttle-bodies (due to the rpm capabilities of my engine 52 mm throttle bodies would not provide enough air at 7,500+ rpm so 58 mm throttle bodies were used).
