[ QUOTE ]
It is my experience that my alternator pushes about 13-14 amps for about 20 minutes and then drops to 10-11. Any idea what may cause the drop?
[/ QUOTE ]
Hold on a sec - are you reading amps or volts? The CAV has a voltmeter, not an ammeter. Is that what's dropping from 13-14 to 10-11, or have you actually installed an ammeter? If you've got a 1-wire alternator, you need to hit a certain rev level before it will start charging - could that be what you're seeing?
(and this subthread should probably go in the tech section...)
