Has anybody tried to use the roof scoop as cold air intake system? I would think it would give a ram-air type effect if done right.
Due to the size of the 5.4L mod motor with a supercharge, I am going to have to reshape the rear window area. I am looking at just making a solid panel with a raised section to clear the motor. I am wondering if it would be possible to connect to the roof scoop and run it the full length of the rear window and connect it to a air-box for the intake. This would split the window into two pieces, then I could either put split windows in or solid panels with vents to help cool the engine area.
I know I would have to make or come up with something to make a seal between the spider section of the body and the rear clamshell for when it is closed to not lose the ram-air effect.
I may also have to enlarge the scoop on the underside to enlarge the the over all area to allow for more air to pass though.
