Neal, Since I am using EFI, I wanted fuel press, fuel level, H2O temp, oil temp, oil press, volts, tach and speedo (>= 160mph) all identical. The closest I came was with Classic Instruments, http://www.classicinstruments.net/default.htm , using their Hot Rod series with a Traditional series fuel press. They put the same pointer on it as the Hot Rod and it already had the same bezel, so it is very close. They were good to work with and the only thing that was somewhat questionable to me is the speed signal modifier they use, Dakota Digital. I have heard some not too complementary opinions of Dakota Digital.
