SPF Front Hub Seal Prototype
| Superformance GT40s Sponsored by Superformance. |
| | LinkBack | Thread Tools | Display Modes |
| | #1 (permalink) |
| Mark IV Time Machines Motorsports ![]() Join Date: Sep 2001 Location: W. New York GT40: P2269,2270,2271
| SPF Front Hub Seal Prototype Workng on a seal for the SPF GT40 front inner hub. The issue is that the "tunnel" for the nut on the tie rod end intersects the void that we are trying to seal. I have a moulded plastic cap retained by an "O" ring. This still leaves a 1/4" or so by 3/4" open into the hub area. The cap would keep most water and grit out of the bearing area but it is not water tight. One could use some waterproof tape and seal off the small area that the cover does not seal. Pictures follow. What do you guys think? Would this help or is it not worth it?
__________________ The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get... |
| | #2 (permalink) |
| steve c Steve ![]() Join Date: Jul 2005 Location: Boston, Ma GT40: SPF GT40 P2125
| Re: SPF Front Hub Seal Prototype Rick, I'll call you tomorrow re ordering parts as previously advised. re the Hub Seals: Would it be possible to seal the gap with RTV or silicon after the cap is installed? If so would probably be OK, no? Steve P2125 |
| | #3 (permalink) |
| Re: SPF Front Hub Seal Prototype That will work, I just assumed some people wouldn't want to do that. If there is interest in the hub seal I will continue. We will use them on our chassis and use a "low adhesion" RTV to seal the gap.
| | #4 (permalink) |
| TU152 Silver Supporter ![]() Join Date: Oct 2008 Location: Asheville, NC GT40: Mk II GT40P2124
| Re: SPF Front Hub Seal Prototype I already have that.....made by Caplug. Steve, the 'tunnel' is the opening I described earlier, and the only way to enclose this area is to make a mold and produce them. The cost to mold the part is small in comparison to making the mold. Guessing at what I've paid before ~ $1400-$2000. I haven't been able to get a firm quote because I still need a drawing to be quoted. I feel this 'fix' should fall back to Superformance because of the cost. Meanwhile keep them dry. Grady P2124 |
| | #5 (permalink) |
| Re: SPF Front Hub Seal Prototype Grady, I talked to a couple of outfits and got quotes in the $1500 area......however as the left/right are different, double he cost! The piece cost is in the $3.00 range but the tooling UGH!! With just 170 potential customers, the earnback does not work.
| | #6 (permalink) |
| Wally Hunt Silver Supporter ![]() Join Date: Apr 2009 Location: Erie PA USA GT40: KVA / GTD
| Re: SPF Front Hub Seal Prototype Rick If you have a Machine shop near by that has facility's to freeze the rubber and a CNC they could program these to be an exact fit. Two programs 1 for the right 1 for the left. Then there would be no gap to worry about, And once initial setup is done these should be reasonable to make. |
| | #7 (permalink) | |
| Re: SPF Front Hub Seal Prototype Quote:
| | #10 (permalink) |
| P2164 Gold Supporter ![]() Join Date: Jun 2007 Location: Arkansas GT40: SPF 2164 07-07
| Re: SPF Front Hub Seal Prototype Very nice!
__________________ SPF GT40 MK1 and a bunch of other stuff Typing is not my bag To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
| | #11 (permalink) |
| Re: SPF Front Hub Seal Prototype Jack, What do you mean "nice"? We don't have them yet. Waiting on Rick for these and a few other goodies he is working on. BTW I have purchased his rear window and the seal kits he is selling for ther A/C evaporator and panel openings...real nice products! Now we need to get him working on the other items. Is anyone working on brake duct kits for front and rear brakes? Once the front hub seal is available and there won't be a problem with dirt/dust getting into the wheel bearings I want to install brake ducts. Easy to do the ducts but, someone needs to come up with the backing plates for attachment to the front and rear uprights. Steve P2125 |
| | #12 (permalink) | |
| Mike Drew Silver Supporter ![]() Join Date: Feb 2005 Location: Vacaville, CA GT40: None, yet!
__________________ Mike Drew, Vacaville, CA ( To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ) '72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1.... | |
| | #13 (permalink) | |
__________________ SPF GT40 MK1 and a bunch of other stuff Typing is not my bag To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | |
| | #14 (permalink) |
| wolodymyr Bronze Supporter ![]() Join Date: Jan 2004 Location: Scotland GT40: DAX40
| Re: SPF Front Hub Seal Prototype Guys, I just came across this thread, don't have an SPF or any need myself, but wondered if the following would be a possibility for the Hub Seals. In the thread you are talking about tooling costs, presumably for injection moulding. Well years ago, I made some one off bearing isolators and spring enhancers from a pourable, self curing rubber like material called Devcon. I suppose that RTV, silicone sealant is similar. Anyway, the reason that the tooling is so expensive is it has to resist the injection pressure and temperatures. With a diy pourable material, you could make an open mould out of wood or anything suitable, and just pour the stuff in. Does this help, or have I not understood your issue? Dave
__________________ DAX 302 Seat Belts Installed |
| | #15 (permalink) | |
__________________ The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get... | |
| | #16 (permalink) |
| Re: SPF Front Hub Seal Prototype Rick, in other words you're 'on the case' already. Well best of luck with it, and hope you find a neat solution. ![]() Dave
| | #17 (permalink) |
| Re: SPF Front Hub Seal Prototype Rick, Keep us advised as to the progress on the "hub seals". Would imagine ALL SPF owners will want a set. Do you think you will have available B4 this Spring? Also let us know what else you are working on. Jack, Thanks for the tip that Dennis has the "brake duct kits". I'll give him a call tomorrow. Steve P2125 |
| | #18 (permalink) |
| Re: SPF Front Hub Seal Prototype Steve, Goal is before the salt is off the roads here in the Northeast, i.e. by mid-March.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| SPF GT40 AC box seal kit | Mark IV | Superformance GT40s | 10 | 06-10-10 07:23 PM |
| Door seal improvement | TU152 | Superformance GT40s | 13 | 10-14-09 07:25 AM |
| 302 front cover oil seal | simonjrwinter | GT40 Tech - Engines/Induction/Exhaust | 13 | 12-06-07 02:41 PM |
| Valve stem oil seal identification | Lee | GT40 Tech - Engines/Induction/Exhaust | 1 | 10-05-04 05:53 PM |
| Door seal channel installation. | GT40 Tech - Chassis,Brakes,Tires,&Wheels | 5 | 05-29-02 05:17 PM | |
