We need some advice and suggestions. Just now getting the engine going since the rest of the GT is done and we are having some issues.
<B><U>Engine specs:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
302 ci.
Compression 9.37 : 1
Chamber volume: 60 cc
Comp cam / hydraulic rollers
Dart Pro head
Intake valves: 1.94
Exhaust valves: 1.60
<o></o>
Carb:
Weber IDF x 4. Venturi was changed from 36 to 32 by T and L while dyno testing to get appropriate performance. Idle jets are #60. The carbs are balanced per the air flow meter. Idle mixture screws out about 1 to 1 ¼ turn each. Idle stop screw about 1 turn past initial contact. We have tried the 'best lean' technique for setting the mixture screws, but it is really hard to tell whether it is correct or not.
<o></o>
The engine starts right up and idles nicely around 800 to 900 RPM. When cold it spits a bit. Once warmed the spiting at idle is minimal. When the engine is driven or reved, however, it spits and backfires through the RPM range.
<o></o>
The engine does not seem to have much power, but given the spitting and backfiring and vibrations it is hard to tell.
<o></o>
The spitting does not seem to be from any particular cylinder. It is random.
<o></o>
Now here is the real problem. There is a significant vibration, worst between 2500 and 3000 RPM. It occurs when the car is reved whether parked or while driven. The vibration is much worse than I would expect even for an engine bolted essentially directly to a monocoque chassis.<o></o>
<o></o>
Some ideas:
<o></o>
1. Timing? Perhaps it is naïve of me to assume that a dyno tested engine was timed correctly. (Not sure what the optimum timing would be for a 302).
<o></o>
2. Balance? The engine is 28 ounce. Surely T and L did not use the wrong harmonic balancer / damper. But perhaps the flywheel from Kennedy Engineering was not 28 ounces? It had no markings on it or any written documentation when received but I was assured in a follow up phone call that it was 28 ounces.
<o></o>
3. Valve issues? Rocker arms? The rocker arms that came with the engine have been known to have some issues, and I have a replacement set waiting ready to install.
<o></o>
4. Carb adjustment? The car does not seem to have the dreaded ‘dead spot’ in the transition zone around 2500 – 3000, but given the vibrations we have not pushed it hard so can’t really say for sure. Can’t quite see how the carbs would be responsible for the vibrations.
<o></o>
This is new territory for me and any suggestions on where we should start would be welcomed.
Dart Pro head
Intake valves: 1.94
<o></o>
Carb:
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
Some ideas:
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
