Authenticity
since you showed a drag car and hot girl here are some fun facts
Did you know …
… that the nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 8,000 horsepower, about 43 times that of the average street car?
… that one cylinder of the eight cylinders of a Top Fuel dragster or a Funny Car produces 750 horsepower, equaling the entire horsepower output of a NASCAR engine?
… that the gasoline-powered engines of NHRA Pro Stock cars produce about 1,200 horsepower, about eight times that of the average street car?
… that an NHRA Top Fuel dragster accelerates from 0 to 100 mph in less than .8-second, almost 11 seconds quicker than it takes a production Porsche 911 Turbo to reach the same speed?
… that an NHRA Top Fuel dragster leaves the starting line with a force nearly five times that of gravity, the same force of the space shuttle when it leaves the launching pad at Cape Canaveral?
… that an NHRA Funny Car is slowed by a reverse force more than seven times that of gravity when both parachutes deploy simultaneously?
… that NHRA Top Fuel dragsters and Funny Cars consume between four and five gallons of fuel during a quarter-mile run, which is equivalent to between 16 and 20 gallons per mile?
… that NHRA Top Fuel dragsters and Funny Cars use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run?
… that NHRA Top Fuel dragsters and Funny Cars travel the length of more than four football fields in less than five seconds?
… that NHRA Top Fuel dragsters can exceed 280 mph in just 660 feet?
… that from a standing start, NHRA Top Fuel dragsters accelerate faster than a jumbo jet, a fighter jet, and a Formula One race car?
… that a fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time?
… that the fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 pounds, about 20 times greater than the pressure on passenger-car fuel pumps?
… that depending on size and angle, the large rear wing on an NHRA Top Fuel dragster develops between 4,000 and 8,000 pounds of downforce?
… that the 17-inch rear tires used on NHRA Top Fuel dragsters and Funny Cars wear out after four to six runs, or about two miles? Some brands of passenger-car tires are guaranteed for 80,000 miles.
… that it takes just 15/100ths of a second for all 8,000 horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels?
… that it's desirable for an NHRA Top Fuel dragster to race with its front wheels inches off the ground for about the first 200 feet of the run? This ensures proper weight transfer to the rear wheels, a crucial part of a good launch and quick run.
… that the nitromethane used to power the engines of NHRA Top Fuel dragsters and Funny Cars costs about $30 per gallon?
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1&1/2 gallons
of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel
at the same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive
the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive,
the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the
flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapour by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of
an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to
blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at
an average of over 4G's. In order to reach 200 mph well before
half-track,
the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to
light!
* Including the burnout the engine must only survive 900 revolutions
under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew
worked for free, and for once NOTHING BLOWS UP, each run costs an
estimated $1,000.00 per second. The current Top Fuel dragster elapsed
time record is 4.441 seconds for the quarter mile (10/05/03, Tony
Schumacher).
The top speed record is 333.00 mph (533 km/h) as measured over the last
66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up
the road, a Top Fuel dragster is staged and ready to launch down a
quarter mile strip as you pass. You have the advantage of a flying
start. You run the
RC211V hard up through the gears and blast across the starting line
and past the dragster at an honest 200 mph (293 ft/sec). The 'tree' goes
green for both of you at that moment. The dragster launches and starts
after you. You keep your wrist cranked hard, but you hear an
incredibly brutal whine that sears your eardrums and within 3 seconds the
dragster catches and passes you. He beats you to the finish line, a
quarter
mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you
200 mph and not only caught, but nearly blasted you off the road when he
passed you within a mere 1320 foot long race course.
And now on to the good stuff.......................... Ya it's thread drift but he is never going to build a GT40 anyway.
Moderator Edit -
sorry but this is NOT the Paddock and I had to delete your pictures.
Please lets get this thread back on topic or just let it die once again.. Else I will be forced to lock or delete the thread...
Thank you...
Randy
If you add "build quality" to the mix, the top contenders mentioned here will surly reset in a different order. Remember those booger welds we discussed in the past.
