I'll throw in a few thoughts - I have had the opportunity to personally inspect, photograph, dimension and measure
chassis's 1008, 1030, 1032, 1054, 1070, Tennant chassis 1126 and 2 unknown serial number Tennant
chassis. The differences in Mark I "Abbey Panels" between chassis are far greater than the differences
between a Tennant Panel Chassis and a Mark I chassis. In my opinion, the Tennant panels chassis is a real GT40
in every sense of the word. As an Automotive Engineer at Ford, I can vouch
for the fact that that the Tennant Panels chassis are indeed stamped/pressed. No doubt a certain
amount of "hand work" is/was needed while assembling. Good examples are with chasis 1008 and 1032
where the B-pillar construction near the air inlet is not symetrical. The left hand side is 6" wide, the right
hand side is 5.625". In addition, the flare for the opening is a good 10 degrees off left to right.
The Tennant panels cars varied
a bit on a few details (for example the early Abbey Panel cars had 2 holes for steering column tilt
adjustment while the Tennent panels had 4 holes for adjustment - possibly part of the improvement
process - more holes would allow more adjustment.
Lastly, my experience with spending the last 6 years measuring GT40's is that the cars are all different. I can
site numerous differences between the chassis especially in the 1005 to 1030 range where many updates,
changes, improvements, design changes, strengthening were made. Changes to accomodate the Mark II,
changes in the front wheelhouse /cowl to allow greater turn angle, changes in the tub for fuel crossover, even
changes in the rear susp pickup points over time. These are facts, not opinions - I have the
documentation/dimensions to prove it. One recent difference we discovered was the difference in shifter
gate plates between Larry Dent's 1005 and 1070. It appears they must have had a problem with shift throw travel and
between 1005 and 1070, the shifter plate increased in length from 5.565" to 6.250" with a subsequent
gate increase of .875".
GT40's are all different. I rarely had dimensions be equivalent. In some examples, the seat pan was
welded at a different X station between chassis. In others, the battery box was moved or changed
positioned. The list goes on and on. Windshield A-pillar construction details are vastly different
between chassis ....ok I will stop.
My point is this, the Tennant Panels chassis, such as Chris Melia's and Lee Holman's are Real GT40's
in my opinion and deserve equivalent respect. As for the history of how the tooling ended up at Tennant is
a mystery that needs explaining.....
