RichardH
AKA The Mad Hat Man
Hi again folks
If I can ask another prospectively dumb Q about cooling systems?
I have a GTD based '40 (with the Alloy Header tank situated behind the driver) that takes approx 12Litres of coolant. I have a new (12psi, i think) cap on the header tank, but every time I run the car it pushes out what seems to be between a pint and a litre of coolant through the overflow pipe. I assume that this is just heat expansion of the coolant; but, because the header tank is only just above level with the top of the engine, I am concerned about coolant levels, and therefore top up the tank before every trip.
This is, annoying, if nothing else, to have to carry a bottle of coolant wherever I go, because the water pushed out is just lost.
Short of having a larger header tank made, which I do not wish to do, is this normal?
Should I not be concerned?
I assume a higher pressure Rad cap might help, but would put a strain on the other components and seals?
what do other people find?
would a capture tank be a worth while addition, or is that being silly?
