Simple hub and adapter drawings;
Had to re-draw some of the parts so here they are, had major problems uploading the drawings this week...finally just took a photo of each drawing and downloaded them.
I omitted most of the dimensions, in the case of the wheel they would be particular to that wheel only. The hub would need bearing bores to fit the particular upright being used, and bolt holes for the wheel pins and rotor hat would need to be drilled and tapped. My dimensions are particular to my setup.
On the hub there is a 3/8" setback to allow for the adapter, and the adapter is drilled thru. This could be left solid with only space for the bearing retainer nut and cotter pin.
The 3/8 setback on the hub allowed me to keep the original 56" track width. The original hubs had a 1/2" thick flange, and machining off 3/8" would have left next to no material for supporting the adapter. I kept the stock location for the rotor hat, just beefed up the area which didn't add much weight at all.
The photos aren't great, but give a good idea of how the parts look.
Hope some of this helps
