Why does your torque slingshot up and down? Other than you dyno, I don't recall seeing any liek that?
That thing made a ton of power.
Thanks Roberto! I might have to reconsider my setup....:lipsrsealed:
Do you guys know of any that exist?
Running without any boost.I think it made more than a .... *gasp* ... rotary :shocked::shocked::shocked::shocked:
That intake setup does look badass. Besides being easier to tune, would it make more power than the ITB setup?
How goes this bubble top scoop that is in the works to accommodate the intake? Any "in the ballpark" references to other cars for ideas?
No, it's still gonna be more restrictive.
I wouldn't say sacrilegious. If you're running wide open throttle for an extended period of time you'll probably see less of a difference between the two setups. There's gonna be a big difference in throttle response though. You're going to have to fill those plenums with air before you can fill the cylinders with air, bit of lag time there. The cylinders are still sharing an access point to the air with the XR. ITBs should lessen the effects the cylinders have on one another. It depends how aggressive you want to get with your power delivery.
