I\'ve got a good brain teaser.
Ok folks. I have a good brain teaser for you.
Some relevant data. Engine is 351W (427 CID) with Ford Motorsport “Street Rod” short water pump driven CW at 1.25 times crank speed (Standard OEM ratio). I believe the thermostat is a high flow Robertshaw 180 degree model.
Recent trip to SAAC 29 included some open track in my GT40. Completed about 25 - 30 hot laps, etc. Was having one cooling system related issue. At no time before incident did the manifold coolant temp sensor register above 85 deg C. Coolant stayed between 80 – 85. At full throttle second gear (~6000 RPM) after the car was warmed up I ejected a freeze plug from the engine loosing all of the coolant in rapid fashion. I put in a new freeze plug and ejected it again after about 15-20 hot laps.
There was no evidence of coolant coming out of the radiator cap into the overflow tank. After some limited “at track” diagnostic work I had concluded that I either had a sticking radiator cap or a combustion leak into coolant. Later at home I installed a rubber expanding type freeze plug (tightened to the hilt). I did a cold compression check with all cylinders between 215 – 222 psi (normal). Did a warm (at TDC) leakage test with all cylinders between 2.5 – 4.5 percent leakage (normal). Did a hot compression check with all cylinders between 220 – 230 psi (normal). Thus it would appear there is no combustion leak.
Next I devised a method to monitor coolant system pressures and installed some gauges at lower left block drain plug, lower right drain plug and in expansion tank (vent input line). I measured pressures as follows for a warm engine:
GT40 at high idle ~1500 RPM:
Left block ~15-20 psig, Right block ~15-20 psig, Tank ~10 psig (rad. Cap closed).
GT40 at ~5500 RPM on street in 2nd gear:
Left block ~125 psig, Right block not measured, Tank ~8 psig (rad. Cap closed).
Pressures always came back down as one might expect if the pump was creating the pressure as opposed to a combustion leak.
For reference I measured a stock 1992 Mustang 5.0L at 800 RPM:
Right block ~12 psig
Stock 1992 Mustang 5.0L at ~5000 RPM sitting still with no load:
Right block 50 psig
Having never measured cooling system pressures this seems very high in the GT40. To try to get some useful information I looked at the SAE paper for the new Ford GT cooling system design I was surprised to see the cooling system drops while Engine 5846 RPM, Pump 7518 RPM, Radiator flow 71 GPM are: Engine 38 psi, Engine to radiator 19.6 psi, radiator 5.4, radiator to pump 2.5 psi, intercooler 5.8 psi. Assuming that the intercooler is in the main circuit that equates to a total pressure drop around the circuit of 71 psig which must be produced by the pump. Thus if a 16 psig radiator cap is used and located at the low pressure point of the system (pump inlet) then the maximum pressure would be 71 plus 16 = 87 psig. Seems ridiculous but less then the 125-130 psig that I measured.
Any ideas on what could be causing the pressure? Is it normal (I think not)? And what can be done next to check or correct it. Help greatly appreciated.
Right block 50 psig
