Shaun
Hi
Ok need to lift the engine onto the bench, got Brodix heads, no inlet manifold so cannot lift on a card plate, am I able to lift using the heads? Bit worries as they are aluminium?
Any idea the bolt size needed if so? On the flywheel end I can for now use the bell housing bolts but once the box is fitted it will have to be lifted by the engine.
Got a load leveller to help
shaun
shaun
