Re: Noon Motor questions
That's the Oberg "tell tale" system....I used one in tandem with a remote mount standard oil filter on a 1971 Mercury Comet (like the Ford Maverick) into which I swapped a 351 Cleveland and the 12 piece header system left no room for an oil filter on the block. I used the canister filter as a "pre-filter" in front of the Oberg, never had the "Tell tale" light come on.
An added benefit to the Oberg is that it offers some heat reduction if you place it where there is airlfow.
You can get filter screens for the Oberg system in a variety of filtration levels...they are also used for filtering transmission fluid.
Cheers!
Doug
Cheers!
Doug
