RCR Front Suspension Help
Hi everybody,
I ordered the last year my RCR-40 MKI Deluxe Plus Kit disassembly in order to import it to my country. Im ready to start my building but, I noticed the chassis does not has the holes for the upper arm and shock absorber´s brackets. Could you provide the right location to drill these holes?
Thank you very much
Thanks Rick,
I did buy it from them. But I ve couldnt get their replay. I think they are having busy time moving into their new facility.
Fran is probably very busy with the move. I've been trying for the last 2 weeks to nail down somebody to see when my 917 may be finished so I can plan my holidays accordingly, but so far have not been able to get in contact, which is unusual.
Chuck
All dimensions measured from the center of the top screw on each upper bracket.
All three brackets, top screw, 13 inches from bottom of vertical panel.
Measuring from the aft weld seam: rear most bracket screw is 7 7/8. Middle is 13 7/8. Front is 19 7/8.
These were measured with a tape measure and should be within an 1/8". If one gets that close I would expect it to be fine, given the adjustability of the suspension.
