Rcr gt40 # 14 for sale *SOLD*
Status
Not open for further replies.
Ron McCall
I really HATE to do this but I am going to have to offer my RCR GT40 for sale.
It has been a true pleasure owning it and I have nothing but praise for Fran Hall and RCR .
I'm sure I'm missing something but here goes:
RCR GT40 #14
Chassis:
RCR Aluminum Monocoque Chassis
RCR Billet Aluminum suspension
RCR full roll cage
AP Racing brakes
RCR stainless steel brake lines
Willwood brake/clutch master cylinders
adjustable balance bar
RCR spec sway bars
15"X8" /15"X10 BRM wheels (Hoosier TD tires)
17"X 8"/ 17"X 9.5" BRM wheels (Hoosier R6 tires)
QA1 Coilover shocks ( two sets Race /Street)
Hyperco 550#/ 400# springs( Race)/ QA1 400#/400# (Street)
Optima red top battery
2380# curb weight
Body:
RCR GT40 Mk1
Original style rear tail lights
Two hood inserts (painted and striped )
Hartswell type body latches
Aluminum door "eyebrows"
Windveil Blue paint
White stripes and roundels .( vinyl / removable )
Engine:
SVO NASCAR dry sump 9.2" deck block
Yates cylinder heads ( port work by Robert Yates Racing)
Titanium valves
T&D shaft rocker system
Ross custom dished pistons(11.2:1 compression ratio)
Carillo connecting rods
Sonny Bryant lightweight crankshaft
Weaver Bros 5 stage dry sump oil pump
SVO high rise single plane intake manifold
Custom solid roller camshaft
Roller camshaft bearings
Ernie Elliot NASCAR valve covers with valve spring oilers built in
1 7/8" custom exhaust with 3" "race" X-pipe and Magnaflow 3 1/2" mufflers for street use
MSD 6 series ignition
MSD billet distributor
High torque mini starter
670hp 520 lb/ft on pump gas
Cooling system:
RCR aluminum radiator
Meziere electric water pump
Canton tank
transfer pipes ceramic coated and thermal insulated
NASCAR remote thermostat housing
Fuel system:
Pro Systems custom HP carburetor
Aeromotive A-1000 fuel pump
Holley "black pump"( transfer left to right )
Aeromotive bypass regulator
Interior:
Custom aluminum steering wheel center with proper FORD GT center emblem
RCR Ultraswede seat covers
RCR Classic Instrument gauges (Speedometer,Tach, Oil pressure,Oil Temp, Water Temp,
R&L Fuel level)
Custom aluminum center console with reverse lockout on shifter
Transaxle:
ZF -2 built by Dennis Quella (Pantera Performance )
Kennedy bellhousing
Mcleod aluminum flywheel
Mcleod Twin disc clutch
External slave cylinder
RCR cable shift
RCR u-joint driveshafts
Priced for immediate sale @ $76,000
Thanks,
Ron
Re: Rcr gt40 # 14 for sale
Ron - There's a fella on the ffcobra forum looking to purchase a GT40 (look in the Off topic - other cars section)..
Couple other things you might want to mention:
What displacement is the engine?
Heater / Airconditioning?
Will it run on 92 Octane?
Ron McCall
Thanks Randy
No AC ,No Heat
360 ci
Runs on pump gas.
Dalton,
You have no idea. :(
Good luck with the sale. I've always thought that GT40 was one of the best looking ones I'd seen over the years. Really looks the part.
Julian
Beautiful car and sorry to hear you are parting ways. I would seriosuly consider this car, but alas it has come a little early for me.
For a couple reasons I made a consious decision to sell my current GT40 and purchase a later version and was thinking of a CAV as they have the best headroom. Your RCR is most definitely a lot of car for the money, but there is still some work to do on my current 40 to get it to a saleable condition so it will be a while before I can commit to a replacement.
Steve Briscoe
Ron-
That's a great car and I'm sure it will sell soon! You're running about 110 horses per liter on pump gas. That's certainly very possible with the right specs. If at some point it fits into the sale process, please consider posting the specs on the engine. I'm collecting information for the 5 liter I'll be putting together for an MKI.
Thanks,
Steve
I can't believe your car is for sale Ron, so sorry to see you've got to let it go. This is by far my favourite GT40 on here, it's a simply stunning machine and a real credit to you.
Good luck with the sale and I hope everything works out.
Trev
Jim Rosenthal
I've seen this car, and met Ron. It is beautifully built, it is formidably fast, and the new owner is going to have himself some high old times.
Ron, you will go through GT40 withdrawal- a very serious medical condition- so you will have a standing invitation to drive mine when you wish. It won't be as fast as yours, though.
Ron,
Sorry to hear that you're parting with your pride - are you going to have it at the Carlisle show on 5/22/2010?
John
Ron,
I have got to say you along with Bill D and Dean's RCR40's you guys have been my inspiration towards my RCR order. I am saddened that you guys have chose to sell these fine cars, but I hope to be able to inspire others along the way as you have for me. I understand life has its changes though.
Happy motoring Sir.
Ron McCall
Ron,
Happy motoring Sir.
Thanks Allen!
Ron's car at Carlisle yesterday...
I took two videos but I am not up with how to post them. From outside at idle and from inside the car moving. This is one really smoking car...:shocked::shocked::shocked:
That primal sound of NASCAR engine roar...!:shocked::shocked::shocked:
Status
