OK here comes the fun part . The driver side catalytic converter got glowing red hot, I mean really really hot . The engine is running like crap, something is going on. It took a while to figure it out . Did engine diagnostics and figured out that I had plugged the crank position sensor in the wrong plug . Dumb , Dumb, Dumb, OK plugged it correctly, engine runs great and cat starts glowing again, the coating craps out and turns dull . Engine overheats over 230, water starts boiling . Whats up now?
First problem, the radiator overflow tank , bought in on eBay, probably Chinese made , the flange is manufactured wrong, not thick enough , the cap does not create a seal, therefore air enters the system . Took a while to figure out
Fix: bend tabs on the cap (I can get creative sometimes ) and voila , problem fixed . Tank sealed, system bleeds itself (Thank you very much Howard )
Why does this crap happen to me ? badly manufactured overflow aluminum tank , seriously? Then I remembered I had to re tap the threads on the same freaking tank , it was not fully threaded .
Well, I will probably have to replace it , but everything is working well,
Cat is still getting super hot . entire outside surface glowing bright red in only a couple of minutes. Fuel problem? a bunch of fuel got dumped when the crank sensor was connected the wrong way? , coil problem? This one took a while to solve. So I created a new post to explain the details .
The cat needs to be replaced, (it looks like crap ) but the problem is not solved yet
