Scott
Rich, I bet you only wait long enough for the edge to cool My understanding is that the "flowing through the radiator too fast reduces heat transfer efficiency" argument is wrong. It's true that the longer the water is in the radiator, the more it cools. However, as is cools the delta T decreases and heat transfer efficiency therefore decreases. Assuming that you have a properly sized and designed radiator you'd rather flow faster so that the delta T is higher which results in higher efficiency. Increased flow also increases turbulence which is a good thing when you're trying to reject heat (my point in the prior post). There is certainly a point where too much flow is detrimental, but I think that manifests itself elsewhere (i.e., pump cavitation) before it effects heat transfer efficiency in the radiator.
A couple of more points on the Pierburg. If I recall correctly, the race SL-C never had to run the pump greater than 70% duty cycle. Also, there are lots of crap Chinese fakes out there so you need to be careful. The picture below shows how compact the pump is (ignore orientation) and what a legit box looks like.
