ZF gearbox clutch lever wanted
Peter Barnes
Hi, help please, I am looking for a clutch lever, either original style or one of the Safir type or even a Pantera one which I can work with.
Thanks, Peter
Morten
Mortified GT
Hi,
This is a pic of one of mine, clutch arm and slave cylinder is from Southern GT
Perhaps its an option for you in UK.
Otherwise Safir or Cushman Racing in the US might be an option.
Good luck
Morten
Doc Watson
I found one a few years ago, the following photos show the 'lug' being brazed onto the arm.
Charlie Farley
Hello Peter,
I think... ( i need to check ), i have a couple left over i had cast and broached, from restoration projects.
You can check them out here, along with other correct period original restoration parts. I believe i may
also have some of the ancillary parts, like clutch stop etc. These have not broken in serious usage.
Perhaps best to contact me through my website.
Best
Andrew
Peter Barnes
Hello Peter,
Best
Andrew
Hi Andrew,
I have looked at the lever on your website. It differs from the one in the parts list drawing above. I believe there were slight differences. I see Andy (Doc) had to alter his to accommodate the stop you mention .
However I am interested, how much do you want for one ?
Thank you , regards, Peter
Charlie Farley
Well, the 'Father' of that casting came off a recognised P chassis that was entirely unmolested. You know, the parts book is not entirely correct. If you look closely, the sketches of some parts are not the exact part that was eventually used by FAV. As per our original chassis drawings, racing deadlines drove the show, not updating drawings with revisions. After all, these cars were not deemed likely to last more than a season.
However, i have checked the parts sketch, i see no major differences.
Please contact me through the website.
