PSE wheels for sale 17x9 front 17x11 rear as pictured
17x9 front 17x11 rear they are in great shape $1600 plus shipping . I will remove the tires
Devin
I don’t recognize the numbering as anything relating to the PCD (pin center diameter) or the backspacing (as measured from the back of the pin face to the back edge of the rim). There are good videos on YouTube if you need help finding these. Other potential buyers will need to know these to see if they will work for their cars since there are so many variables.
Some further information required back spacing 17x11 has 4 11/16" and 17x9 has 5" and the pin diameter is 3/4" on 4 5/8" Bolt circle
I see you have GTD on your intro page. Did these come off of a GTD? GTDs have an unusual bolt (pin) pattern. If they are off a GTD and would fit mine then I would be interested.
Devin
Bob, thanks for getting the dimensions. Unfortunately the backspacing and pin pattern won’t work for my build.
