Bulkhead window gasket/surround
I visited my local glass guys to chat about cutting a rear bulkhead window for me and the gasket (if that's the correct term) they offer is HUGE. I've searched on the net for smaller, lower profile items to no avail. If someone could point out a reasonable source for a window gasket, it would be appreciated. It's shaped somewhat like an "H" with the top holding the glass and the bottom holding the bulkhead.
Many Thanks
Brian
Hi Brian
My DRB uses goop (no gasket) on either front screen or bulkhead glass.
I guess different kits use different designs...
MikeD
Thanks for the lead Brian, I'll give them a look. I thought about copying the original design and "gooping" it in, but making the metal flange surrounding the glass would be quite an effort.
Brian
Hi Brian,
try trimlok.com They have a great selection of trim to fit your application. I just had some samples and a catalog sent and they look great. They have both the sigle lock and two piece lock designs as these pictures may help.
