Eyeball vents another option
I wanted the authentic look and could not find any with the grid in the eyeball.
The picture shows some made from the standard item with a grid fitted into it.
Steveb
Steve,
nice work !!
What did you use as the base part, and from what car ?
Any details of how you achieved this would be great.
Cheers,
John.
Dutton
Steve,
To echo Johns comment, nice work! any chance you'd like to share the details?
T.
Thanks for the comments.
The eyeball I started with was the 50 mm vent available from many sources, I cut out the center divider and then bored the spherical clear through. After a fair bit of trial and error the size of the dividers was determined, ( I would like to get the acual split ratios; I used for the the cross dividers 25% 50% 75% of the diameter)
I made a cad drawing in 3d to get a set of profiles that would interlock and cut them on a cnc, with a bit of fettling to match up the contact points the core 'eggcrate was a snug fit. The face edges are then dressed to match a spherical profile. the thing is then glued in place.
I am quite please with the result
SteveB
