Ford GT40 Mk1 project with Corvette C5 front and rear uprights.
Bonjour à tous.
J'étudie encore depuis quelques mois déjà pour faire une Ford GT40 Mk1.
Après les conseils de certaines personnes sur le Forum, j'ai décidé de suivre leurs conseils et d'adapter les montants avant et arrière de la Corvette C5.
Je cherche donc ici les dimensions concernant les montants arrière et avant. J'ai joint 3 photos des dimensions attendues. Si quelqu'un peut m'aider en moi les illustrés ou s'il y a de la documentation disponible, ce serait très gentil de votre part
Hello everyone,
I've been studying for a few months now to make a Ford GT40 Mk1.
After the advice of some people on the Forum, I decided to take their advice and adapt the front and rear uprights of the Corvette C5.
I am therefore looking here for the dimensions concerning the rear and front uprights. I have attached 3 photos of the expected dimensions. If anyone can help me with the pictures or if there is any documentation available, that would be very kind of you.
Because then these dimensions I will be able to integrate them into the chassis and also see to adapt 15-inch rims as well as the brake calipers and discs.
Thanks in advance to all for answers.
Olivier.
Hello Olivier: I cannot provide these data. Not sure if they are available online. However, if you definitely are going to use them I would say your best bet would be to purchase the components first and then design the chassis ``around" them. There is a discussion on the C5 wheel bearings on this site. Best wishes for your project.
Brian Kissel
Olivier posted this almost 4-1/2 years ago and hasn’t signed into the forum since September of 2021. But continuing to update this thread will help others searching for similar information. Things change all the time and the more information the better.
Thank You
Regards Brian
