Hi, I am currently listing my GT40 replica on ebay. It's listing can be found here; GT40 KIT CAR (tornado) unfinished project | eBay
The details of the vehicle can be seen below. Please see the ebay listing for images.
GT40 REPLICA TORNADO KIT CAR (UNFINISHED PROJECT) THIS IS A VERY REGRETTABLE SALE DUE TO LACK OF TIME AND OTHER COMMITMENTS. TO-DATE I HAVE INVESTED OVER 400 HOURS INTO THIS PROJECT AND SPENT WELL OVER 10K IN PARTS ALONE, AS YOU CAN SEE IT IS A FULL ROLLING CHASSIS, THE CHASSIS HAS BEEN SHOT BLASTED THEN ZINC COATED THEN POWDER COATED IN GLOSS BLACK AT A COST OF £1300, ALL SUSPENSION ARMS + LINK RODS + GEAR CHANGE + VARIOUS OTHER BITS AND PIECES HAVE ALL BEEN BRIGHT NICKEL PLATED AT A COST OF £1200, THE CHASSIS IS FITTED WITH 4 NEW PROTECK GAS ADJUSTABLE SHOCK £500, + NEW STEERING RACK AND COLUMN £195, 4 NEW 17INCH IMAGE WHEELS WITH NEW TYRES AT A COST OF £2000, IT IS FITTED WITH WILWOOD BRAKE CALLIPERS, NEW DISC AND PADS, BOTH FUEL TANKS ARE FITTED WITH NEW FUEL SENDERS,I HAVE ALL THE ALLOY CHASSIS PANELS WHICH HAVE BEEN CUT AND COATED IN GLOSS BLACK AND ARE READY TO BE FITTED PLEASE NOTE ALL WORK TO DATE HAS BEEN DONE TO A VERY HIGH STANDARD
THE ENGINE IS A FORD 351 WINDSOR WHICH HAS BEEN FULLY RE-BUILT BY VALLEY GAS SPEED SHOP AT A COST OF OVER £2000 (DETAILED RECEIPT PRESENT) THE ENGINE IS FITTED WITH EDELBROCK MANIFOLD PLUS HOLLY CARB THE ENGINE HAS BEEN ESTIMATED TO GIVE BETWEEN 300 & 350 BHP. ALSO I HAVE 2 DIFFERENT SETS OF EXHAUST SYSTEMS AGAIN THE WINNING BIDDER CAN CHOOSE FROM
THE GEARBOX IS A RENAULT UNI 21 WHICH HAS BEEN FULLY RE-BUILT BY CHRIS COLE AT A COST OF £1000 (RECEIPT PRESENT) PLUS 2 RE-BUILT DRIVE SHAFTS AT A COST OF £350
THE BODY WORK HAS BEEN STRIPPED READY FOR PAINT PREPARATION BUT PLEASE NOTE I HAVE 2 FRONT NOSE CONES AND 2 REAR CLAM SHELLS SO THE WINNING BIDDER CAN CHOOSE, BOTH DOORS ARE FITTED, I HAVE VARIOUS BONNETS OF DIFFERENT DESIGNS AGAIN FOR WINNING BIDDER TO MAKE THERE CHOICE. THERE IS A NEW DASH (NOT FITTED) 2 CREAM LEATHER SEATS, 2 4 POINT HARNESSES. I HAVE ALL DOOR HANDLES PLUS LOCKS PLUS IGNITION, AND ALL STAINLESS STEELS BRIGHT WORK, ALL FRONT / REAR LIGHTS / INDICATORS PRESENT, PLUS VARIOUS OTHER BITS AND PIECES
NEW PARTS NOT FITTED :
COMPLETE NEW WIRING LOOM £200
NEW DASH £200
NEW SET OF GAUGES X5 £400
NEW FUEL LINES PLUS FITTINGS £300
NEW FUEL PUMPS £100
NEW OBP PEDAL BOX £300
NEW BRAKE MASTER CYCLINDERS PLUS SERVO,S £250
NEW HANDBRAKE CABLES PLUS FITTINGS £150
NEW ALLOY RADIATOR £250
NEW HEADLAMPS £150
NEW HEATER SYSTEM + AIR CON £1000
NEW STAINLESS STEEL FRONT NOSE CONE MOUNTING BRACKETS £100
NEW STAINLESS STEEL REAR CLAM SHELL MOUNTING BRACKETS £100
PLUS VARIOUS OTHER SMALL BITS AND PIECES
ALL THESE PARTS ARE BRAND NEW AND NOT FITTED I HAVE ALL THE RECEIPTS PRESENT TOTALLING £4200
THE CAR IS FULLY REGISTERED WITH DVLA AS A TORNADO GT40, I HAVE FULL V5 (LOGBOOK) PRESENT PLUS ALL ENGINE / VIN NUMBERS / TAGS
AS STATED ITS A VERY REGRETTABLE SALE AS I HAVE INVESTED A LARGE AMOUNT OF TIME AND MONEY INTO THIS PROJECT, HERES A GREAT OPPORTUNITY FOR SOMEONE TO GRAB A BARGAIN AND TO SAVE THERE SELF ALOT OF TIME AND MONEY. OBVIOUSLY THIS IS AN UN FINISHED PROJECT, BUT WITH VERY LITTLE TIME / EXPENSE I,M SURE THIS WILL BE ONE OF THE BEST GT40 IN THE UK
NEW DASH £200
NEW FUEL PUMPS £100
NEW HEADLAMPS £150
