New RF Pricing structure
After several months of hard work we finally nailed down a system I believe will help more people afford the car.
We still offer the Deluxe kit but now we have added a new twist to the line up. You can now purchase a rolling chassis then purchase module packages of which there are ten to complete your GT. Each module package will contain all items pertinant to assembly of that module. As an example if you purchase the fuel tank module it will have all the fittings,hoses and pumps. Everything needed to put the fuel system into the RFGT.
The Roaring Forties web site will have these prices on it as soon as we get the site updated.
Here is the new module price list.
Rolling Chassis $21,500.00
+ Shipping
Part # Description
40-0 Body Chassis Kit
40-1 Powder Coat
40-2 Floor
40-3 Fit Floor
40-9 Suspension Package
40-11 AVO Shock Set
40-12 Sway Bar Kit
40-14 Steering Column
40-15 Steering Rack
40-16 Steering Rack Mounts
40-17 Intermediate Shaft
40-18A Mota Lita Steering Wheel
40-19 Peddle Box & Push Rods
40-20 Brake Master Cylinder
40-21 Brake Master Cylinder Spacer
40-22 Clutch Master Cylinder
40-23 Front Calipers
40-24 Rear Calipers
40-25 Hand Brake Calipers
40-26 Front Brake Rotors
40-27 Rear Brake Rotors
40-28 Rear Brake Rotor Spacers
40-29 Brake Hydraulic Lines
40-30 Brake Light Switch
40-31 Braided Brake Lines
40-33 Slotted Rotor Upgrade
40-34 Hand Brake Lever
40-35 Hand Brake Cables
Module # 1 Aluminium / Body Hardware $6,700.00
Part # Description
40-4 Aluminum Panel Set
40-5 Rivets
40-6 Sealant
40-29 Clutch Hydraulic Lines
40-31 Braided Clutch Lines
40-69 Body Hinges
40-70 Door Hinges
40-82 Door Handle Set
40-83 Door Lock Kit
40-84 Stainless Steel Over Centre Catches
40-85 Body Locating Cones
40-86 Dzus Fasteners
40-91 Door Seals
40-94 S/S Body Straps
40-95 Aluminium Edge Finisher
40-114 Vacuum Formed Dashboard
40-123 Bolt On Halibrand Wheels
40-125 Front Tyres 205/55/16 pair
40-126 Rear Tyres 255/50/16 pair
40-127 Bolt In Tyre Valves
************ Aluminum panels and body Fitted (Labour Only) $7,300.00
FAST BUILD $35,500.00
Rolling Chassis + Module # 1 + Aluminium Panel and Body Fitted + Shipping
(Labour Only) constitutes a FAST BUILD KIT
Module # 2 Cooling System $1,350.00
Part # Description
40-37 Aluminum Radiator
40-38 Thermostatic Fans (Pair)
40-39 Cooling Pipe Set
40-40 Modified Thermostat Housing
40-41 Radiator Header Tank
40-42 Radiator Bleed Line
Module # 3 Fuel System $1,600.00
Part # Description
40-44 Fuel Tanks (Pair)
40-45 Fuel Tank Fitting Kit
40-46 Fuel Filler Caps (Pair)
40-47 1 Pump Fuel System
Module # 4 Glass Components $800.00
Part # Description
40-71 Front Windscreen
40-72 Front Screen Rubbers
40-73 Bulkhead Screen & Rubbers
40-74 Rear Screen
40-75 Rear Screen Rubbers
40-89 Windscreen Wiper Motor Kit
40-90 Windscreen Washer Kit
Module # 5 Instrumentation $2,000.00
Part # Description
40-104 Switch Kit
40-105 Smiths Gauges
40-49 Fuel Tank Senders
40-106 Remote Oil Sender Block
40-43 Ball Vents
40-80 Dashboard Demister Vents
Module # 6 Wiring $2,100.00
Part # Description
40-97A Vehicle Wiring Harness
40-110 Battery Box & Hold Down Clamp
Module # 7 Drive Train Package $3,250.00
40-51 Serpentine Pulley Kit
40-53 Engine Mounts
40-56 Gear Box Mounts
40-57 Engine Stabiliser Bracket
40-58 Engine to Gear Box Adapter Plate
40-59 Flywheel
40-60 Clutch Assembly
40-61 Clutch Release Bearing
40-62 Spigot Bearing
40-63 Starter Motor
40-64 Drive Shafts
40-36 Accelerator Cable
40-32 Clutch Slave Cylinder
40-107 Alternator
40-108 Alternator Brackets
Module # 8 Lighting & Body Fixtures $1,350.00
Part # Description
40-76 Side Windows
40-77 Headlight & Indicator Cover Set
40-79 Le Mans Panel Set
40-98 Front Headlights
40-100 Front Indicators
40-101 Rear Tail Lights
40-101A High Level Brake Light
40-102 License Plate Lights
40-103 Reversing Lights
40-111 Horn
Module # 9 Interior Trim $3,350.00
Part # Description
40-112 Interior Trim Kit
40-116 Black Vinyl Seats with Brass Eyelets
40-120 Sash & Lap Seat Belts (4 point)
Module # 10 Exhaust $2,800.00
Part # Description
40-67 Cross Over Exhaust
40-68 Rear Body Heat Shield
Options & Upgrades
Air Conditioning Kit $1,990.00
Pin drive Wheel Upgrade, BRM or Halibrand $1,000.00
Limited Slip Differential $1,550.00
Motec 8 Barrel Injection, including upgraded 3 pump fuel system, $8,250.00
engine harness, all sensors, linkages and MoTeC M800
Mark II Rear Clip Upgrade $1,600.00
Gurney Bubble (Supply Only) $90.00
Fitting $350.00
Single Nostril Panel (Supply Only) $260.00
Wheel Flairs as per GULF car 1075 (4 piece, Supply Only) $330.00
Fitting $850.00
Race Seat (Each) $385.00
Mota Lita Steering Wheel Upgrade $130.00
AP Racing Caliper Upgrade $2,700.00
6 Piston Front Calipers, 4 Piston Rear Calipers
Wilwood Brake Upgrade POR
Koni Shockabsorber Upgrade $2,000.00
Fire Extinguisher, 4kg capacity FAI approved $755.00
Full Roll Cage $2,800.00
Half Roll Cage $1,600.00
Now that makes a lot of sense. Robert and Hershal are to be congratulated on designing a modular approach that will make it easier for long-term builders to get into an RF. I know exactly how I'll spec out my next one. /ubbthreads/images/graemlins/laugh.gif
No doubt RF has continued to improve the breed since chassis # 36 was produced. Not that I'm complaining! /ubbthreads/images/graemlins/smile.gif
What chassis number is RF up to now anyway?
Thanks Mark,
We think it was the best way to offer this car. To me it was the only choice rather than sacrificing quality then you wouldn't have an RF. I truly believe that if a less expensive GT40 could be built it would have been done by now.
I believe that RF is on chassis 90 or 91, not sure but I bet Robert knows. /ubbthreads/images/graemlins/wink.gif
Thanks for sending me this information the other day Hershal. Its a difficult decision to make as to manufacturer...I really like the idea of the SPF but can't get any information out of them....what has been posted on this site is the culmination of all information out there. I will be calling you about the options I have since I am looking at getting this car a year from now and believe I should start working towards the end goal now rather than later.
Again thanks for all your hard work.
Matt
427Aggie /ubbthreads/images/graemlins/grin.gif
Hey Matt,
I'll make your decision a little easier if you come out to Phoenix for a visit here. One drive in the RFGT40 should do it.. /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
PS. Matt, I'll even put you up for a day or two and you can hang around here and be submersed in GT40 stuff. And you know me..I'll talk your ear off. /ubbthreads/images/graemlins/grin.gif
Scott McDill
Hershal,
Great Idea for those who need to spread things out a bit. I noticed the Rolling Chassis is price + shipping. Is shipping included in the price for each module? Will the leather interior option be available? Does this mean I will have to tell my Minister of Domestic affairs the real reason why we bought a large grage with a small house attached to it, or why her crazy husband is building a ford engine when we dont even own a ford? /ubbthreads/images/graemlins/wink.gif
Hi Scott,
The shipping is not included. It's about $3200 USD. Shipping for the modules will be from Phoenix. Shipping Cost will depend on the wieght of the module crate.
Leather is all we now offer. so it is now standard.
Scott, all I know is that you are one ssmart cookie if you pulled off a bigger garage than house purchase. I wouldn't worry about the Ford engine as most women haven't a clue as to what kind they are /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
Thanks Hersh,
For your info, the UK prices will exactly reflect the US prices. There is of course the issue of VAT and I am checking out the import tax situation at the moment (I have been told about 3 different things at the moment!)
Rick
Robert Logan
Let me give praise where praise is due :
the idea for the modular system was a combination of Rick and Hershal. They both thought that the shipment would be a lot easier if we did it this way and that would make life easier for our customers and distribution people. Areal win - win situation.
Best wishes,
Robert
Gordy
Did I miss something ? The price for a complete kit is 46,000 or bought as modules 56,000.
Hersh, I think you have a good idea but I have a concern.
Is there a guarantee that an individual who buys a RF this
way over a couple of years would get the full kit if RF40
changes hands or goes out of business?
"God forbid" as my Mother would say.
Is there a time limit to purchase this way?
Steve /ubbthreads/images/graemlins/cool.gif
Scott McDill
Gordy,
As soon as I saw this thread I had to break out my calculator for a comparison. I might be wrong but I came up with $46,800 for the rolling chassis plus all of the modules. I left out the $7,300 for aluminum pannel fitting, as I think this is an option (and its not included in the base price for the deluxe kit either.) For a fair comparison I added the $1990 AC option that is included with the deluxe kit for a total of $48,790. Add about $1500 for shiping of the modules for a final total of $50,290. (I left out shipping for the rolling chassis since it is about the same as the shipping for the deluxe kit) Is this about right Hershal? Or am I missing somthing?
Gordy,
The price of the rolling chassis and all of the modules comes to 44K. If you throw in the A/C option it brings it to $45990. What you did was add from Quick build option. Which brings it to your total. The quick build has all of the panels in place and the body is fully fitted with door latches, locks and all of the body mounting hardware such as centering cones, latches and fasteners in place. If you don't want the fast build then deduct $7300 labor charge from the total. It is true that additional shipping fees will apply if you just buy one module at a time but that shipping cost will be from Phoenix not Australia.
I hope this helps.
Steve,
Robert Logan is a very good business man as well as a GT40 nut like all of us. I believe as long as there is interest in these car then Roaring Forties will be around for a loooong time. What really will keep RF's doors open is the quality of the car. It is to well sorted to fall by the wayside. Yes. I do sell Robert's cars but I truly believe in his product. The module package idea gets more people in the game. I don't know anything on earth that's for sure except death and taxes but if I was a betting man I would put my money on RF being around for many many years. I think Robert started the business in 1997. His company has steadily grown into what it is today. The only reason this could happen is because of a great product.
Hersh,
I really like the concept. It will get me started sooner than I had planned.
I did not find the shifter assembly in the packages. Did I miss it?
Thanks, Keith
No Keith, you didn't miss it...We did. Thanks for catching it. I will have it changed. I believe it was to go under the Drive train Module #7. /ubbthreads/images/graemlins/shocked.gif /ubbthreads/images/graemlins/wink.gif
