I have done a stupid thing here.
When I bought my GTD, I had it trailered to my home and have spent some time "fettling" it before I started driving it. I have checked and replaced various parts, as it was built in 1988.
The one glaring mistake I made was to check the gearbox oil level. I took the car for a run of about 10-15 miles but as I approached my home, I could hear a "whine" from the gearbox. It suddenly dawned on me that I had not checked the oil level at all since I bought the car. When I arrived home, I removed the filling plug and found I was able to put almost a litre of oil in before it came out of the hole. I started the car again (I have not driven it since) but upon engaging the gears it is still whining. It sounds a bit like a worn release bearing, but activating the clutch makes no difference, only having it in gear.
I am guessing that I'll have to pull the gearbox out to have all the bearings replaced as I'm sure I have done it no good at all. Is this something I could do myself? I'm a bit wary of any gearboxes as they seem to be a bit of a "black art" to work on.
Has anybody worked (successfully) on their own gearboxes, or is this best left to an expert?
Thank you.
Yes, I have searched the drivetrain forum.
Thank you.
