I doubt that you will get only one answer here too, and I dont specialize in engines at all but this is generally what people do. Note that at first,it is the cam you want to pay attention too and generally you cam manufacturerwill have specific instructions
1. When you first run it, buy a proper break-in oil, not synthetic or your normal oil.
2.Start the engine, run at around 1500 rpm till it is warmed up or you notice something catastrophic is about to occur, if it is just something minor like a coolant leak, dont stop unless you absolutely have too. When the engine is warm, shut it down and let it cool.
3.Now i usually pull the valve covers and oil pan and recheck the bolt torque, change the oil to clean break-in oil, run it at 1500rpm again till warm and do some basic timing and idle adjustments.
4.Drive it, at first, do some hard acceleration and deceleration but keep the rpm above 1500 and below 4000, do that for as long as you can stand it. Then just drive it for about 500 miles but dont let it idle if possible and dont cruise at a constant rpm, always be either lighly accel or lightly decel (decel under engine breaking, not with the clutch in).
5. Change the oil again to a normal mineral oil, not a synthetic, and drive it for around 3500 miles (or whatever interval you change the oil normally) but again no idling and no redline pulls (yeah right, that one never lasts) but you can start driving it a bit more normally.
6.Change the oil to whatever you will be using and drive it like it is stolen.
That is how i do it.
