Terry Oxandale
Skinny Man
Not being someone who can just look at it and tell if it is a good and even surface like a pro-bodyman may, I have to use my hands, close my eyes and rub my hand over the body gently in the powdery dust "feeling" for high or low spots. Feeling for consistency in the contours. If the line is already cut between the panels, it upsets the movement of my hand and I lose track of the contour..
Maybe I'm nuts, but it's the best way I have found to do this.
Not at all! In fact, this method works better than using other senses until I do a wet sand where the sheen reflects the straight-tube florescent shop lights (per Fred'a note) to show deviations of thousandths of an inch. Finding a perfect material for an idiot stick or sanding block is as much the art as is feeling the surface. 3M make some really good foam pads that come in a variety of stiffnesses, as well as some interesting stiff-foam longer sanding blocks that I've seen up to 18" long for those very slight curves used on our cars.
Here is a wet-sanded surface after rinse-off. The water stayed on it long enough to push it into the garage and review the work under the florescent tubes. They were very telling. This first photo looked pretty good.
This second photo (the other side of the rear panel) showed the flaw I felt with my hand, but couldn't see. Notice how I sanded through a couple of different shades of primer, yet the hump (sharp bend in the reflection of some PVC tubing hung at the ceiling) in the center of the photo, was still there indicating I still had some work to do.
