Hi all,
Roy Smart and I use a R21 turbo box as Malcolm describes (Un1), it has been modified in two ways. Firstly, the main shaft has been built by Quaife with a straight cut first and higher ratios on first and second. The larger diameter input shaft is also one piece to the spigot bearing, thus removing the problem of the quill shaft breaking where it had been necked down on the standard item. The spline is also now 'Ford' instead of Renault giving a wider choice of clutch options.
This Shaft / Gear modification was designed by a GTD club member and is available from Quaife, with his permission, as a retrofit kit of parts.
The strength of these parts was proven at the Wiscombe Hill Climb this year, when Dave Parker (GTD-R42 / Chevy 350) had the pin supporting a planetary gear break in the std diff. This pin exited the differental and attempted to pass between the crown wheel and the bevelled pinion gear to which it normally meshes. The resulting 'Bang' burst the Renault casings apart (depositing a 100yd oil slick) but all the Quaife parts survived unscathed. Once fitted to another casing - Dave was back up and running again.
Secondly, we and others now use the Quaife ATB differential which thus far has performed well. Our 0 to 60 mph has been recorded at 3.7 seconds with 100mph in 8.6.
The failing of the std diff seems to stem from 'excessive wheelspin' which in turn causes the two planet gears to rotate at very high speeds. These then overheat, sieze, break their supporting pin etc etc.
Ray Christopher uses an Audi 6-speed in his GTD-40 spyder which is beginning to show form. Watch this space..
regards
Paul Thompson
ps - the 'bang' mentioned is shown 'in-car' on this years GTD Club Video - 150 mins of '40' fun.
For details of video (currently PAL only) - Contact club & forum member
[email protected]
[ December 15, 2001: Message edited by: P Thompson ]
