I’ve got a few comments to make about the Motec products. Maybe GIC can share some thoughts on some of these for us. I’m not trying to create a flame war, I’m just curious about a few things that only a Motec dealer/distributor could accurately comment on.
First of all, understand that I think Motec products are GREAT!!!! However, I live in the real world where money doesn’t grow on trees, and it’s important to get the most benefit for dollars spent. This is where (for me, anyway) Motec falls down. I’d like to address each of the points GIC brought up one at a time, starting with a quote and then my question.
From GIC:
1) Motec controllers (ecu) prices start at $1600 for the M4 controller. The M48 (very popular with the V-8 crowd) is $2591.00.The "flagship" of the product line, the M800 is $4500. Agreed, that is expensive and probally more ecu than most would require, unless you are considering serious racing endevors.All of these units will run a V-8 no problem, with the added convience of using a vast array of trigger and ignition schemes.
From BK:
1) I have absolutely no doubt that the Motec ECUs would brilliantly control any engine combination that I’m ever likely to throw at it. Motec has also done a terrific job of offering a very comprehensive array of additional options and accessories, most of which are very cleverly executed, and have a modular “plug-and-play” nature that I’m sure is envied by all programmable ECU makers. Where I have to jump off the Motec bandwagon, however, is when I look at the cost of the ECUs and the options that I’d be most likely to use. I would be interested in hearing/reading some justification for the cost of these things. The typical response that “you have to pay a lot more to get the very best” will not cut it. Programmable Engine Management Systems are becoming more and more commonly used, and there is more and more competition every day from other ECU makers. Premium features that used to be the Motec staple are now found on many of the much more affordable management systems. How will Motec respond to these changes in the ECU market?
From GIC:
2) For those of you who wish for a "distributorless" direct fire and/or coil on plug ignition, an ignition expander is used in conjunction with the ecu. The expander is $325.00. In those configurations both crank and cam signals are generated by a Ford distributor as in the TFI or also refered to as the "narrow-tooth" trigger.Many other techniques are available as well to suit the individual tastes or requirements.
No Other Controller Offers This Versatility.
No Other Controller Offers The Ability To Choose Any Injector Available To Match Flow Requirements For Fueling.
And this is but the tip of the iceberg, when it comes to what you get for the price of the Motec.
From BK:
2) I can only speak for myself and the products that I’m familiar with, but I’d like to comment on your statements that “No Other Controller Offers This Versatility” (ignition triggers, I think) and “No Other Controller Offers The Ability To Choose Any Injector Available To Match Flow Requirements For Fueling.” Depending on how many cylinders/rotors used on the engine in question, there are several other non-Motec ECUs that offer flexible triggering options, and most any programmable ECU will allow you to use whatever injector you need in order to suit the fueling needs of the engine in question. The obvious exceptions to both of my above statements would be (respectively):
A) Those systems offered as a direct replacement for a particular vehicle’s OEM computer; and
B) The ‘wanna-be programmable’ engine management systems that work by altering the OEM computer’s inputs and outputs in order to manipulate the resulting engine operation to achieve the desired results.
The primary issues with regards to the injector selection is of course whether the injector output drivers are able to drive both low and high impedance injectors, and whether or not they can operate the number of injectors necessary to fuel your engine.
Haltech systems (on the other hand) are perhaps the most flexible of all in terms of what will work as an appropriate trigger. Where it’s true that Motec offers an option to use the Ford TFI distributor with the long/short-pulse home/trigger, most people who want distributorless ignition don't WANT a distributor for anything other than a means to drive their oil pump! Furthermore, most of the people I’ve spoken to argue that the distributor is a bad place to get a trigger signal, citing the ‘slop’ that exists in the cam chain/belt and the inherent inaccuracies that it creates within the ignition system. That means the Motec expander is a $325 option with a built in handicap! This would not be a smart purchase, in my humble opinion.
From GIC:
3) Any Motec Controller will use a "narrow-band" O2 sensor (Bosch). This is without extra charge. If one wishes to have "wide-band" O2 for high-performance tuning, all Motec controllers come with 6hrs. of "engine run time" to aid in the tuning for your engine.After that the option for "wide-band" O2 is $770.00.
From BK:
3) I don’t feel that the ability to use a narrow band O2 sensor is something that a Motec guy would wish to be boastful about. Just about every programmable ECU system offered these days includes this as a standard feature. I do find the Motec ‘Professional Wideband Lamda Meter’ to be an exceptional value and relavance, though I do rather think that for the cost of the Motec systems, the built-in wideband option should be a standard feature, rather than a $770.00 add-on. Also, could you please elaborate on this 6 hours of “engine run time?”
From GIC:
4) Software is,and has been Free.I invite everyone to visit at
www.motec.com, and click on the 'software' button and take whatever they wish.This is operational software and will run a motec controller, it is the real stuff guys.
From BK:
4) I don’t think that this is a very fair statement to make. The software that you can see and play around with (and get a fuzzy feeling in your tummy, spurring you to reach for the AmEx card) is free, but you have to pay fees to unlock certain functions. Where it’s not wrong for Motec to handle their upgrades in this fashion, I find it to be a little silly that someone talks about ‘free software.’ For what it’s worth, if you want Haltech software, I’ll give it to you. It’s no big secret, folks! Realize that there is a lot more to a system/company’s merit than whether or not their website offers free downloads for their tuning software. Bandwidth costs money, and every time you download software, somebody has to pay for it. The more a company spends to make it’s software available, the more they’ll charge those of us who actually end up buying the system. They MUST pass on their operating costs to the consumer, as that’s just how running a business works.
From GIC:
5) Motec Systems U.S.A. and Motec World Wide,
work dilligently to provide the best-bar none support after the sale in our industry.
We are very serious about this. It is a PRIME directive.
Having said that, we will make all resonable attempts to halt the importation of ecu's and related gear by non-offical methods.Every component is serialized and will be very difficult to get operational if it is "bootlegged"!
From BK:
5) I’m totally with GIC on this point. Motec does do a great job of supporting its product, and I’m sure that’s where a good portion of the cost of each system comes from. I’ll also stand behind GIC on the issue of grey-market ECU imports. When customers cut domestic retailers and distributors out of the loop, everyone ends up losing. If we’re not able to market these products, then we can’t earn a living. Then people who buy grey-market products come to us expecting support, even though they know they cheated us out of our slice. Ethics and fairness dictates who gets help and who doesn’t, and I think it’s fair for domestic retailers to refuse support to those who bought from and overseas supplier. A little money saved up front can cost you big-time later down the road. Your dealer should help you find solutions to your issues. Don’t expect another dealer to give technical assistance for free if you didn’t give him/her an opportunity to make the sale.
From GIC:
6) Harnesses can be custom designed and built by us or by one of our specialists around the country. I know of NO $3000 engine harnesses that were produced by us. Although for clarity, Motec has state-of-the-art systems that entail much more than just the engine loom and these "combined"constructed (read:"the whole car")harnesses can and do get into the $3000-$4000 range.These are very, very sophisticated constructions, and are not good comparisons to engine harnesses.
From BK:
6) The MIL-SPEC connectors (canon plugs) offered as an option by Motec are seriously nice if you’re building a full-effort racecar. For most of us, it’s huge overkill unless you want to be the ‘Boulevard Pimp’™ and impress your friends. Those connectors are very costly, and are extremely labor intensive when building the finished harness. Time spent assembling the harness, the special tooling required, and the materials themselves all add up to what is hard to call an economical solution. Depending on how much time it takes a technician to build a wiring loom, $3000 might not be so far out of reason. I give credit to Motec for even being willing to provide this level of custom wiring as an option.
From GIC:
So in review, a M48 with an ignition expander and 8 coils for direct fire and a typical engine harness, will be in the$4600.
range. Note : this is a Fully Sequential control with idividual coil per clyinder ignition.
Thanks for hearing me out, and good luck on all your projects.
gic
From BK:
In review, the Motec systems are still very serious money. If you want to do an 8cylinder sequential and distributorless waste-spark ignition (sorry, the E11 can only do 6 cylinders in coil-per-plug configuration at present time) you can buy the E11 kit ($1500), termination kit ($80), and MAP sensor (cost varies by application.) Add four waste-spark coils with ignitors, and you will be money ahead in most cases, rather than buying the more costly Motec offerings. In closing, I think that Motec has some fantastic products. I really just think that they’re cost prohibitive and impractical for most of us who are just building performance vehicles for pleasure/personal use, rather than race cars with sponsorship dollars at stake. Motec certainly has it’s place, but I don’t think it’s under the boot/bonnet of most casual enthusiast vehicles.
Respectfully Yours,
Brian Kennedy
