Boy what a fantasic body
Boy what a fantastic body ...grille.
If you look at the posts that sound like a womens body is exposed the hits on that thread are high.
I'm Looking at different options for the rear deck aperture grilles.
If you have some pictures of some different styles that would be good.
If your just a pervert like most of us are your out of luck
Cheers anyway
I'll add some fantastic body photos, but not from the angles you are requesting:
Is this what you are referring to??
I believe the grille is from Racer Parts Wholesale #4 1/4" stainless.
Stainless Steel Wire Mesh
The frame is scrap Stainless cut with a plasma cutter, tack welded to the mesh, and then ScotchBrite finished. They hide the puller fans for the oil and trans fluid coolers. The spoiler vents are unscreened so as to not impede the flow of air and reduce the build up of air pressure in the wheel wells.
The spoiler is homemade and was plasma cut as well. Mounted with large button head screws and large stainless washers. It is spaced from the body by large rubber washers to avoid trapping water and debris.
Malcolm
Leave the rear exposed but not wanting a bald one, suggest you have a top grill only!
