The push rods, it is a general comment John.
I am no familiar 100% with your eng.
Some engine don't run adjusters the rely on the lifter and push rod length.
I have had some older engine that I have had to shim rockers up because of the same problem.
As the rocker is raised of its mount it relieves the load on the lifter.
In you case rod length is important for rocker geo.
I have had some eng that have had to heavier oil cause the same problem.
The thick oil gets into the lifter and sort of goes solid.
If the specs are pull down 3/4 turn back 1 and 7 off.
I usually rotate the pushrod with my fingers when adjusting to feel when the rod and rocker meet.
It may only want 1/4 turn preload.
Jim
Jim
