Here is a closer look at the problem AC fittings. The one that faces out (to the left in the picture) is the biggest problem. It aims right at the tub wall. I may try and make a box in the wall to get clearance.
Here is a better picture of the AC lines.
So why did you decide to not use the included servo controlled heater valve?
Ahhh yes, I remember reading about that issue during my GTM research. I am curious to know what type/brand servo controlled heater bypass valve you are using. The only heater bypass valve solution I have seen is a vacuum solenoid bypass valve.I am using a different type of heater valve located next to the engine. It fully closes the coolant flow and reroutes it back to the water pump when the AC is commanded on.
With the LS engine it has been reported that an over heating condition can occur if you start your engine with the AC on and you have the type of heater control valve that just closes off the coolant flow. It seems the LS engines need a constant loop of coolant flow through the heater pipes on the water pump.
Here is a picture of it connected to my engine in post #6 http://www.gt40s.com/forum/slc-clubhouse/38446-kens-slc-build-thread.html#post386379
My LS6 motored "super 7" did not have heat and I capped off the inlet/outlets off the water pump. I never experienced any engine cooling issues. I've read both sides of the debates on this and still haven't found any definitive answer yet.... but, better safe than sorry. As always-your results may vary.
