Thanks Dave, the luck didn't hold. It was one of those weekends......!
I was hoping to do some testing last Tuesday to check the re-routing of the MSD wiring that I had done to try to combat any possible interference issues causing the miss, also to further progress the suspension/handling department, and also to check the security of the wheel nuts now that I had swapped the spindles from side to side.
Swapping the spindles revealed an unexpected gremlin in so far as I discovered the inner sleeve on the front RHS needle roller had moved. This is an interference fit on the spindle and is not subject to side loads and it was still very tight on the spindle. So that was a real surprise. Easy enough to prevent the movement just by placing a cap screw inboard of the sleeve. However the sleeve had moved far enough to contact and knacker the seal and cage of the roller bearing, so new bearings were required. They had to come from out of town and didn't arrive in time for the Tuesday test session.
Test days ($90 per day) at Ruapuna are Tuesdays and Fridays, but this Friday was a local holiday so the track was not available. It never rains but it pours!
Well, I wasn't convinced that re-routing the MSD wires was going to cure the miss, and I didn't want to arrive at Timaru with it still playing up so I then decided to fit the proven ex-TR7 optical pickup into the Motocraft dizzie, and utilise the Crane XR700 and the coil that went with it. No rev limiter and had to swap the wires on the tach back to the way they were originally! Also had to attend to a couple of minor items that for the previous meeting the local scrutineers, knowing we were time challenged, had been lenient about. At an out of town track I didn't want to push my luck.
Nevertheless, after a couple of weeks of late nights, by 11pm Saturday we were loaded up and ready for a good sleep before our 5:30 departure for Timaru the next morning. Except the good sleep didn't happen, my normally sedate and quiet neighbours had a party in full swing that went into the wee small hours. Bloody typical!! Never mind, them's the breaks.....
The schedule for Timaru was one qualifying session and three races. Rain was threatening and the track was cold. I managed to make a complete dick of myself by doing a 360 coming out on to the track for the qualifying session. Caused I think by that missfire at 4500, just at the wrong time, that I hoped I had cured. No such luck. Anyway no damage, so on with the business.
Levels is a completely different circuit to Ruapuna, shorter and generally tighter and the car was twitchy and still had the miss and was not good off the line, so I decided to treat the day as a test session and asked Race Control to start me off the back of the grid in all races.
In between races we progressively reduced tyre pressures and camber, which improved the handling and times and tried closing up the plug gaps to see if that would get rid of the miss. No such luck!
During the last race I developed cramp in both hands which locked the gearchange hand onto the steering wheel thus unable to change gears. Time to call it quits and DNFed. The cramp was probably caused by the long hours put in on the car and not having decent meals over the last couple of weeks. The things we do......
All in all an inauspicious weekend with an uncompetitive car, I guess it can only get better....
Nevertheless, apart from the results, it was an enjoyable and relatively relaxed weekend. Lim was with me and my other best mate, John, made the trip over from the Coast again specially to help out. Great guys both.
The car attracted a lot of attention and favourable comment, so that was quite pleasing. Sunday showed we are heading in the right direction with the suspension setup and revealed that I will have to look further for that miss. Not difficult, it's just a matter of working through everything. Will make further suspension and electrical changes and do some testing Tuesday week. We have now done about 60 laps in the car. Next race is Dec 13 at Ruapuna.
Going back to an earlier post, you said you couldn't run in a 1hr race because your car wasn't legal for that race. The question is, what class will you be running in, will it be the same class as you ran your TR7 in which I think was "Prodution Sports and GT Cars"
Ironically, in the North Island spaceframes are eligible for the NI Endurance races! Yes, I will be running in Classics, in the 'Sports and GT' class
and of course you know that I'm going to ask if a Can-Am style car could run in that class???? Cheers Leonmac
I think you will run in the class for open top cars. 'Racing and Sports-Racing'
