MDA GT40 in Ohio *SOLD*
Status
Not open for further replies.
I'm selling my GT40 project. Busniess changes for me over the last few years, and a build a bit more difficult than I had hoped, plus a wife asking for a Chrismas gift of listing the car for sale has put me here.
I bought the deluxe kit from MDA with everything needed to complete the build less wheels, tires, engine, and guages. I built a Classic Roadsters Cobra before this and tried to outsource parts to save money.....it didn't, hence the reason for the deluxe kit. I'll list the parts I have, if you think I may have missed something (I just may, I am getting older) just ask and I'll verify.
Complete chassis
All aluminum panels supplied and fitted (except the panel that covered the engine timing cover)
Stainless steel water pipes routed through the central tunnel.
Steering Rack fitted
Front roll bar fitted
MDA bias pedal box assembly assembled and in car
Brake and clutch master cylinders with resevoirs
Stainless steel flexible brake lines
Front and rear Hi Spec 4 pot calipers with pads
Aluminum brake bells front and rear with vented brake discs
Clutch cylinder
Clutch pipes
Gearchange assembly (central mounted, car is left hand drive)
Power cable kit(battery cables)
Complete wiring harness (with switches and dash lights)
Steering column
Steering column intermediate shaft
Throttle cable with rod ends
Aluminum radiator with fitting pack
(2) radiator cooling fans
(2) sill mounted aluminum fuel tanks with explosafe
Fuel filler caps (flip type)
(2) electric fuel pumps
(2) fuel filters
Fuel line kit twin
(2) fuel sender units
Water expansion tank polished aluminum
Engine mounts for small block Ford
Renault UN1 gearbox with 3.44 diff
Gearbox brackets to mount to chassis
Rubber gearbox mounts
Flywheel and clutch kit AP
CV joints kit with boots, boot retainers, bolts, and half shafts
Handbrake lever, cable, compensator
1 3/4" stainless steel crossover exhaust with dual stainless steel mufflers
Stainless steel Muffler heat sheild
Complete body panels with twin nostril bonnet
Body stays
Door handles (pair)
Door handle fitting pack
(2) windscreens (just in case one broke during shipping)
Bulkhead window with fitting rubber
Door windows formed PVC simona
Door windows fitting kit s/s screws and PE trim
Headlamp covers formed and shaped with mounting s/s screws
Spotlight covers formed and shaped with mounting s/s screws
9 hole lemans rear cover with mesh rear covers
dash demister panel
Stainless steel over center body catches
Hood pin retainer brackes for rear bonnet
Dzus fasteners for front clip with s/s plates
Wiper motor assembly, wiper arm, blade
Twin air horn assembly
Air conditioning kit with heater
Carpet set
Seat belt harnesses
Seat harness bar set
Seats black leather with brass rings
Steering wheel with polished center boss
PS Engineering 17" halibrand 6 pin drive knock off wheels
Headlamps with side lights original type
Headlamp fit kit backplates, spacers and screws
Side lamps pair original style lamp
Indicators pair original style lamp
Rear lamps pair original versions
Rear no plate lamps original style
Door rubber fit kit to seal doors upper and lower
Switch kit all dashboard switches
Dash leather wrapped
Thats what I have on my parts lists. The kits included all fasteners for the itels on the list also.
I have over $62,000 invested.
Selling for $42,500.
You can pm me with questions or ask in the thread, if you'd like to discuss anything about the car, I can pm you my phone number or you can send me yours and I'll give you a call, just be patient as I don't get online every day, you know, these darn computers sometimes day 20 minutes to boot up. What a pain.
Jim Downard
My dream ends here.
Re: MDA GT40 in Ohio
Oh yea, I have more photos on our old computer that our kids use. As I get time, I'll pull some pics from that computer and add to the list.
In addition, the rolling supports that are under the car go as well. No sense in having to make your own set.
Jim
Sad to see you have callled time on the project, hope the car finds a new owner soon. Best wishes for the New Year
Steve
Thanks Steve,
I, like Chris, have decided priorities had to be made, and business comes first. Good holidays to you.
Jim
I've found a couple photos of the wheels that I have for the car.
Also, I forgot to mention that I will entertain reasonable offers on the car.
I still need to get a couple photos of the dash and seats. Will get those posted this weekend.
would you be interested in trading for a 78 Porsche 930 with a slant nose kit and a 88 porsche 911 targa?
Sorry Bill, I'm pretty sure the wife would divorce me over that deal. I'm trying to thin the herd, so to speak, around my place and I'm going to have to reinvest in my business and my children's college fund. It was never supposed to take me this long to build the car, but our business plans changed after the 2008 meltdown, and I've not had to spare time to finish the build, and spare the extra coin to pay a builder to finish it.
Price lowered to $37,500. I also have a full instrument set for the car. I completely forgot about them but stumbled across them in the basement the other day. Only thing needed to complete the car is the bodywork, assembly of mechanicals, tires and engine.
Jim, sold my era gt40 two weeks ago (red) looking at yours. If i put in a sbf do i have to do anything with the water pump? Is the renault box strong enouth with the a 400 hp sbf. Pictures og dash,seats, carpeting? Kind regards domenic
Domenic,
I'm going on a family trip with weekend, but when I get back, I'll try and get you the pics you're requesting. As far as the waterpump, no, you don't need to do anything special, the firewall cover has a hump to clear the waterpump. The Renault is plenty strong enough for 400 hp. That's what I was planning to build my 289 up for. I do know that the main clearance concern on the MDA's was the distributor. You need to use the smaller diameter body.
I finally got around to getting the pictures of the seats, carpet, dash, and instruments that are included in the sale of the car.
Jim,
Do you still have the car? I'm looking to sell off a couple of English Motorcycles but time is not working in my favor. Like you, I run my own business but the reality is that the business runs me.
I feel your pain, just got two hours of sleep last night working on a bid for today. Did wind up being low bidder, but man, the hectic pace of bidding, paperwork, keeping the guys going really wears you down. Back to topic, yes I still have the car.
Status
