I'm selling my GT40 project. Busniess changes for me over the last few years, and a build a bit more difficult than I had hoped, plus a wife asking for a Chrismas gift of listing the car for sale has put me here.
I bought the deluxe kit from MDA with everything needed to complete the build less wheels, tires, engine, and guages. I built a Classic Roadsters Cobra before this and tried to outsource parts to save money.....it didn't, hence the reason for the deluxe kit. I'll list the parts I have, if you think I may have missed something (I just may, I am getting older) just ask and I'll verify.
Complete chassis
All aluminum panels supplied and fitted (except the panel that covered the engine timing cover)
Stainless steel water pipes routed through the central tunnel.
Steering Rack fitted
Front roll bar fitted
MDA bias pedal box assembly assembled and in car
Brake and clutch master cylinders with resevoirs
Stainless steel flexible brake lines
Front and rear Hi Spec 4 pot calipers with pads
Aluminum brake bells front and rear with vented brake discs
Clutch cylinder
Clutch pipes
Gearchange assembly (central mounted, car is left hand drive)
Power cable kit(battery cables)
Complete wiring harness (with switches and dash lights)
Steering column
Steering column intermediate shaft
Throttle cable with rod ends
Aluminum radiator with fitting pack
(2) radiator cooling fans
(2) sill mounted aluminum fuel tanks with explosafe
Fuel filler caps (flip type)
(2) electric fuel pumps
(2) fuel filters
Fuel line kit twin
(2) fuel sender units
Water expansion tank polished aluminum
Engine mounts for small block Ford
Renault UN1 gearbox with 3.44 diff
Gearbox brackets to mount to chassis
Rubber gearbox mounts
Flywheel and clutch kit AP
CV joints kit with boots, boot retainers, bolts, and half shafts
Handbrake lever, cable, compensator
1 3/4" stainless steel crossover exhaust with dual stainless steel mufflers
Stainless steel Muffler heat sheild
Complete body panels with twin nostril bonnet
Body stays
Door handles (pair)
Door handle fitting pack
(2) windscreens (just in case one broke during shipping)
Bulkhead window with fitting rubber
Door windows formed PVC simona
Door windows fitting kit s/s screws and PE trim
Headlamp covers formed and shaped with mounting s/s screws
Spotlight covers formed and shaped with mounting s/s screws
9 hole lemans rear cover with mesh rear covers
dash demister panel
Stainless steel over center body catches
Hood pin retainer brackes for rear bonnet
Dzus fasteners for front clip with s/s plates
Wiper motor assembly, wiper arm, blade
Twin air horn assembly
Air conditioning kit with heater
Carpet set
Seat belt harnesses
Seat harness bar set
Seats black leather with brass rings
Steering wheel with polished center boss
PS Engineering 17" halibrand 6 pin drive knock off wheels
Headlamps with side lights original type
Headlamp fit kit backplates, spacers and screws
Side lamps pair original style lamp
Indicators pair original style lamp
Rear lamps pair original versions
Rear no plate lamps original style
Door rubber fit kit to seal doors upper and lower
Switch kit all dashboard switches
Dash leather wrapped
Thats what I have on my parts lists. The kits included all fasteners for the itels on the list also.
I have over $62,000 invested.
Selling for $42,500.
You can pm me with questions or ask in the thread, if you'd like to discuss anything about the car, I can pm you my phone number or you can send me yours and I'll give you a call, just be patient as I don't get online every day, you know, these darn computers sometimes day 20 minutes to boot up. What a pain.
Jim Downard
My dream ends here.
Complete chassis
Clutch cylinder
Clutch pipes
Steering column
(2) fuel filters
Fuel line kit twin
Body stays
Door handles (pair)
dash demister panel
Carpet set
Seat belt harnesses
Jim Downard
My dream ends here.
